Castle Creations 1515 water Jacket
  • mtbenjamin77
    • 761
    does anyone know if the 1512 w/ fins water jacket will fit the 1515 w/fins? I'm just not sure how having fins will affect the length of the jacket.
  • Alexgar
    • Aug 2009
    • 3522
    You put rubber rings arournd the fins and slide the tube over it so it should fit it will just be a little short
    • mtbenjamin77
      • 761
      that's what I was thinking. the 1515 is outta stock on ose so I was gonna try out the 1512. shouldn't be much different the 1515 is only 0.3" longer
      • Alexgar
        • Aug 2009
        • 3522
        I just measure not jackets and the difference was only 7mm 50 as opposed to 57 that would be the fin area. Hope that helps
        • mtbenjamin77
          • 761
          Thanks my friend
          • JimClark
            • 5902
            moved thread
            Billy Graham
            • siberianhusky
              • Dec 2009
              • 2184
              will work fine I run a 1515 cooler on a 1512.
              • mtbenjamin77
                • 761
                I'm trying to do just the opposite. Run a 1512 jacket on a 1515 motor. If the area of the fins is larger will the 1512 jacket fit over the fins?
                • siberianhusky
                  • Dec 2009
                  • 2184
                  I think the 1512 cooler is 50mm long, or at least very close to it so you can check the length of the fins and see.
                  I just measured the 1515 cooler I have and it's 57mm long.
                  Still working my way through the morning coffee, thought about diameter but not the length!
                  Cheers
                  Oh ya are they out of stock at HRC themselves? I got my motors at the big blow out a couple yeas ago, OSE sold out of the coolers quick so I ordered from HRC.
                  • HRC
                    • 316
                    OSE should get delivery on some castle 1515 jackets and time now. The 1512 will fit but you will need to move one of the O rings in a couple grooves on the motor.
                    Dave
                    • mtbenjamin77
                      • 761
                      Good deal. I don't need it right now anyhow. Sometimes we never know when things will be available. I see you have a few on your site so I'll pick one up there if need be. Thanks
                      • Jeremy
                        • Jun 2013
                        • 24
                        And since the 1515 jacket is out of stock for quite a while: will a 1518 jacket fit the 1515?
