Need help with UL-1 Motor.
  • tjw4700
    • Aug 2012
    • 6
    I'm looking at getting a UL-1 Motor for a Tunnel Hull as Randy from BBY suggested that Motor and said that's what he run's in all his Tunnel Hulls that are around 27 inchs long.
    What I was wondering is what s the max timing you can adjust this motor to.
  • JimClark
    • 5913
    What ESC
    Billy Graham
      The max timing will depend on the use. The more amps you pull the more timing the motor needs. Stock timing is 10*, I've run 15* on the motor with a small performance improvement but if you do that watch for heat issues. As Jim alludes to above, the ESC determines the exact timing value you can choose.
      • tjw4700
        • Aug 2012
        • 6
        I'll be running it on 14.8 Volt's and a Seaking 180 ESC.
