Motor mount question
  • chipgibbs
    CG3
    • Aug 2012
    • 184
    I picked up a 40mm Carbon side plate water cooled mount for a leopard 4074.
    Should the rear support ring tighten on the motor can ? Even with the top screw tight, the ring is somewhat loose. I could cut the threaded side of the clamp to allow it to tighten up more.
    Insite appreciated
    Chip
  • iamandrew
    • 576
    Hi there
    Yeah ive noticed mine are the same
    I ended up sanding where the bolt goes through
    you dont wanna clamp down too hard and bend the can though.
    • carlcisneros
      • Jan 2010
      • 1237
      Chip
      bring the motor and the mount to the lake this Saturday and I will show you what to
      do with it that does NOT involve cutting, sanding, ect.
      Carl
      • chipgibbs
        CG3
        • Aug 2012
        • 184
        See you there Carl, Thanks
        • viper1
          • 219
          Originally posted by carlcisneros View Post
          Chip
          Carl
          Want to share it here Carl?
          Wisdom is knowing how little we know
          • carlcisneros
            • Jan 2010
            • 1237
            kind of have to actually show you what I do to the tail ring.
            easiest thing I can say is tilting.
            • 1945dave
              • Mar 2012
              • 295
              No the easiest thing to say would be shiming. But none of this is a problem either way. The rear ring does not need to be tight at all. It's only function is to offer general support while the front mount holds the rotational and centering positioning. Some guys never use the rear mount at all.
              Dave
              • viper1
                • 219
                Hmm.... MYSTERY, love it
                • Basstronics
                  • 2384
                  Mine did the same thing. However it is nice and tight on a TP Power 3082...
