Is there a chart or something that can help picking the correct motor and esc for different size hulls? I'm a newbie and don't have a clue what to use.
motor chart
This is one of the best threads to read for any newb or even me when I screw up and need to referrence something.
It will help very much:
http://www.rcuniverse.com/forum/m_9069147/tm.htm
This may help and the rest of the site has some good info as well.
Ken,
Just as important as choosing the correct size motor is choosing the correct motor KV for the number of cells you plan on using. This chart is usefull in making that choice :
kv_voltage[1].pdf2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Also, if your motor is not listed you can just use this simple equation to determine the RPM unloaded of course. Take the motor KV and multiply with the number of total voltage you will be using. KV x Voltage = RPM unloaded. Example: 2060kv motor x 11.1v (3s) = 22,866 RPM.Originally posted by properchopper View PostKen,
[ATTACH=CONFIG]86128[/ATTACH]
Hope that helps.Last edited by SweetAccord; 10-10-2012, 02:28 PM.
Here are two helpful motor charts
Very nice guys...great info...what i was needing all in one place....tks much .... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
All of these charts are helpful!! Been into FE for a couple of years now but still great to reference these. Thoroughly reading these charts will save you lots of heartache and smoking electronics. !! Dont get caught up in the thinking that higher rpm is faster top speed.....not always. If I can get my boats running 33,000 to 38,000 rpm unloaded....it seems to be the magic sweet spot. Then you can play with props and other tweaking!
