Another new HK motor
  • znus
    Broke, as usual
    • Jun 2011
    • 120
    http://www.hobbyking.com/hobbyking/s...ess_Motor.html
    A bit too small for my taste (wish they would make a ~4585, and that's excluding the jacket) but I guess I'll be pressing the button soon
    25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
  • LOVE6S
    • May 2012
    • 538
    Wow, thats a good deal at 55.00 with the jacket, any idea how big a hull this motor would push and if you ran it on 5s would it be to high of rpm, but thats kinda cool a 2200kv motor that can handle 5s, any thoughts would be good as I am thinking of pushing the button myself, thanks.
    • znus
      Broke, as usual
      • Jun 2011
      • 120
      That motor would fit nicely in something in the 26" - 35" range. I'd run it on 4s with a ~42 mm prop.
      • mtbenjamin77
        • 885
        that' s alittle better than a Feigao 540XL
        Turnigy AquaStar 3973-2200KV Water Cooled Brushless Motor
        Specs:
        RPM/v: 2200kv
        Poles: 4
        Max voltage: 18.5V (5S)
        Max Current: 100A
        Max Watts: 1200w
        Resistance: 0.0094ohm
        No Load Current: 2.9A
        Can Diameter: 39mm (actual motor diameter)
        Can Diameter inc. Water Jacket: 49mm
        Can Length: 69mm
        Shaft Size: 5mm
        Weight: 415g
        not very impressive considering most HK elecs. are over rated
        Leo 4074 ($40 more) and shipped from US
        40mm Diameter by 74mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%.
        Specs:
        Magnets: neodymium
        Watts: 1500 with Over 2000 Burst.
        Poles: 4
        Motor Shaft: 5mm with flat spot
        Can Measures: 40mm diameter x 74mm long
        • iamandrew
          • 576
          I preffer my immitation Turnigy over the leopard in the 4074s, seems to run a lot cooler
          • mtbenjamin77
            • 885
            or try this if you want cheap
            more watts & higher efficiency less IR
            Tacon Brushless Motor LBP4074/2Y-2150KV For 1/8 Buggy/Monster RC Truck:
            $65.81
            You save $16.45 Over 20% saving!
            Watts2600
            Outer Diameter?mm)39.8
            Length (mm)73.8
            Stator38MM
            No of cells (lipo)5
            max efficiency (%)94%-95%
            max efficiency current 120
            no load current (A)/7.4V1.8
            Internal Resistance (mohm)0.0062
            Shaft Diameter (mm)5.0
            Shaft Length (mm)20
            KV (RPM/VOLT)2150
            Turns (for cars)Poles2Y/4POLES
            Max Voltage23
            • jamespl
              • 748
              I'm deffo getting one of these for my pursuit that's in transit. Nice find.
