Is this really a 12's motor?
  • BW won
    • Mar 2012
    • 199
    Leopard 4074, 1050kv, 2600 watt, max amp draw 65 with 45v (@3.7v per cell, 12 cells) as the max voltage, or "lipo cell" as Leopard's website classifies it.
    I suppose my questions should be:
    In general, are smaller motors able to trun at higher rpm's (as apposed to larger ones)?
    what allows one brushless motor to handle more rpm's than another? Quality of bearings and magnet glue?
  • Make-a-Wake
    FE Rules!
    • 6057
    I'd say 8s for sport boating, 8-9s for racing...............10s for SAW's.
    • keithbradley
      • 3671
      It's a 12s motor in a car...not as much in a boat.
      www.keithbradleyboats.com
      • BW won
        • Mar 2012
        • 199
        I thought so,too. However, with a max draw of 65 amps, a voltage of 37 (3.7 volts per cell) would bring the amps to 70+ at 2600 watts (A x V = W or W / V = A). Is this simply not a boat motor?
        • BW won
          • Mar 2012
          • 199
          This would make a lot of sense- my buddy's 1/10th scale castle motor has "good to 100,000 rpm" engraved on it.
          • keithbradley
            • 3671
            The motor will draw as many amps as you can supply, if you load it hard enough. There is no governer on brushless motors, that spec is to assess how hard you can load the motor. To get a 65A draw, you wont be able to spin it that fast with a decent prop. A road car is much lower load, so you could get away with it.
            • Make-a-Wake
              FE Rules!
              • 6057
              Depends on the hull as well. You could actually run it on 6s and use an LV ESC(2-6s) which are alot cheaper. Then you could swing a prop with more pitch to make up for the 'lowish' rpms. Will you just be sport boating??? If so, its plenty on 6s.
              What hull and length?
              • BW won
                • Mar 2012
                • 199
                It was intend to be used in a twin set up for a 41" Apparition- mainly used for sport- really competitive sport . I had a choice of 1050kv or 2200kv for $50 each, so I chose the 1050's so I wouldnt have to buy more lipos ( already had 8s packs). But, after checking the specs of the motor, I started to think I made a poor choice.
                • NativePaul
                  Greased Weasel
                  • 2770
                  It will be fine on 8s.
                  • BW won
                    • Mar 2012
                    • 199
                    Thanks for the info. I thought lowering the cell count ( lowering the voltage) would increase the amp draw, though.
                    • keithbradley
                      • 3671
                      No. That's backward.
                      It will draw more amps at a higher RPM vs. a lower RPM because the load increases.
                      A 1000kv motor will pull less current at 30k RPMs than a 2000kv motor at 30k RPM, but will require more voltage.
                      A 1000kv motor will still pull less at 30k than it will at 35k though.
                      When you go up in voltage on a given motor, the power increase is exponential and experienced on both the voltage and current sides of the equation.
                      • BW won
                        • Mar 2012
                        • 199
                        Awesome, Kieth! Thank you for your knowledge and patients.
