Timing Neu Motor
    55/3 is too much in my opinion. Let us know how it goes though...
    I agree, that is a lot of prop. I did run a modified x455/2 on that motor in my SprintCat where it ran great - but it pulled a lot of amps in the hydro. Just use with care until you know it is okay.
    • electric
      • 1973
      Noted. Jay this is the Prop that Richard(Dallas) was running this boat with while racing the Whip 40 I now have. I have set it up with the same motor and batteries and will even duplicate the CG information he gave me before running. I will take your advice and just make a few quick laps to start and then bring it end to see what I got. Do you think the Eagle Tree will hold up do I can get some data to share with eveyone?
      • T.S.Davis
        • 6266
        None of my Whips liked 3 blade props. Even my 20's. They weren't/aren't quite stock either though.
        Noisy person
        • fas
          There just toy boats
          • 526
          I have ran a 455/2 cupped and pitched runs right around 67 my timing was at 10 deg temps were motor 110 speed control was at 90 that was in a a/c sport 40 hull for q sport was a great set up and only ran 1 p. That was with the 1y
          When all else fails floor it
          • electric
            • 1973
            Great, pretty much what I am going to test except I will use 2p. What were you amps like?
            • electric
              • 1973
              Nothing beats that first time your run a new boat. You just drop it in the water pull the trigger and hope you got it all screwed together correctly. Then there is the issues you will face getting it back if it fails because you are alone at the pond.
              Here is the data from my first q-hydro run. The top speed was only 61.8mph because it was starting to take off on the straights so I was letting off on the throttle. I need to put some more weight in the nose and get the COG adjusted forward. It was still accelerating strong when I let off. I think it may have another 5-10mph in it?? Turns on a dime.
              Still shaking. Chuckle. This is what I love about these fast boats.
