Brushless motor maintenance
  • DORM
    • 27
    This question might be to stupid for most of you guys but im new at this so here I go. Can I just run my Brushless Motor over and over without doing anything to it or is there something I should be doing every so often to keep it running good?
  • jkr
    FE Addiction
    • 582
    Mine after 15-20 runs i lube them.
    • Dan Proulx
      • Dec 2007
      • 41
      You should clean the brushes.
      • jkr
        FE Addiction
        • 582
        • iamandrew
          • 576
          my adivce is to make sure you clean out the water cooling jacket, e.g. put some WD40 through your cooling pipes, because the aluminium water cooling cans can get some corrosion in them
          • jkr
            FE Addiction
            • 582
            That is a must do on every run especialy if you run on sea!
            • DORM
              • 27
              Im not that stupid, its brushless
              • DORM
                • 27
                thanks for the advice guys,every little bit helps , DORM
                • CatMan
                  • Jun 2010
                  • 96
                  I was just about to comment on the "clean your brushes tip"? you said it was brushless. and thanks for asking. I am new to this as well and it never occurred to me about any maintenence on these motors
                  and have never read about wd40 to cooling lines for corrosion. Thanks for bringing this up. good to know. keep asking.... the more you ask the more I will learn!
                  BTW, what boat do you have?.... just curious
                  • BHChieftain
                    Fast Electric Addict
                    • 2051
                    I took advice from forum members and use corrosion x on my tunnel, since when it capsized the motor gets wet. I don't do anything on my mono motors since they stay dry and I'm too lazy to pull them out...
                    Chief
                    • Chuck E Cheese
                      • 2136
                      i lube the bearings at the start and end of each day (get some sewing maching lube with a needle tip to make it easy).. also i am salt water so i flush my outboards with fresh water and spray the internials with corrosion block
                      see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
                      • JIM MARCUM
                        • Jun 2011
                        • 775
                        Welcome to the OSE forum Chris, and to the often dry sense of humor some of us love to flaunt. We're laughing with you, not at you. Don't be afraid to ask "stupid" questions. We've all been there, and questions are the best way to learn the "how To's" of FE boats. We all have more to learn about this constantly changing & complex sport. Hang in there. JIM
                        JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                        • DORM
                          • 27
                          I have a Mistic 29.Miss Elam,Stilleto,Shockwave 26 BL
                          • DORM
                            • 27
                            Thanks for the welcome Jim!
