5692 Leopard Motor. Is a 6mm good enough?
  • Drax21
    • Jul 2011
    • 1077
    I remember seeing this issue raised a while ago. I'm about to start my build and I am wondering if 6mm is good enough?
    I heard some people had actually bent the 5 ans 6 mm shafts on these motors before??
    I also see that Steven has mostly 8mm shafts in the shop and the new HK 56 series motors all have 8mm shaft.
    I want to use it with a 1/4 cable.
    What do you guys think?
  • JIM MARCUM
    • Jun 2011
    • 775
    Haven't bent any of my 5692 shafts. My question is, how could anyone bend a 6mm shaft anyway? Short of dropping the motor on it's shaft I don't see how a firmly installed & well aligned motor could get bent. My new Turnigy 5692 has an 8mm shaft and looks bulletproof, but it's a bit of an overkill to me.
    You should have no shaft problems with a Leopard 5692 & 1/4" flex drive as long as the motor is firmly mounted, is properly aligned with the stuffing tube, less than 1/2" of the flex drive exposed between the ST & motor collet, and the ST firmly mounted at the motor end to eliminate any flex drive whip. JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
    • Drax21
      • Jul 2011
      • 1077
      Ok that's good to know. Thanks for that Jim
      • JIM MARCUM
        • Jun 2011
        • 775
        Thanks. You're welcome. JIM
        • Mel279
          • Dec 2008
          • 873
          I would prefer 8mm, bigger is better..less vibration
          • JIM MARCUM
            • Jun 2011
            • 775
            I'd like to see Leopard 56XX series with a 8mm shaft also. But there's nothing patently bad running a 6mm shaft. How well a motor is designed, built & balanced is key here. If the rotor and shaft are not perfectly balanced it won't make a rat's pitutie of difference running a 6mm or 8mm shaft. JIM
