Etti Motor Mounts
  • JimClark
    • 5913
    Etti Motor Mounts
    What have you guy's been using to glue the Etti Motor Mounts tot he bottom of the hull?
    Just using epoxy and doing a Fillet of Epoxy on each of the 4 sides of the mount or have you been adding wood to increase the gluing surface?
    I made some alum brackets for my 1/10th scale so I could bolt it on but that is not going to work on this boat so got to do something else.
    Jim
    Billy Graham
  • siberianhusky
    • Dec 2009
    • 2206
    Just installed another one in a H&M cat, been using JB weld.
    • DPeterson
      • 991
      Iv'e used various methods over the years including epoxies and JB. A friend told me to try Marine Goop. Best advice I have ever received. Iv'e stuffed my 11-12 pound boats and nothing breaks loose. The other nice thing is the goop set fairly quickly - you can build a boat in a day.
      Doug Peterson
      IMPBA 19993
      www.badgerboaters.com
      • LarrysDrifter
        Big Booty Daddy
        • 3416
        Ive been using Z Poxy finishing resin mixed with milled fiberglass. Mix to a putty like consistency and neatly apply. Havent had anything break loose yet. Had many bad wipe outs and still holding strong.
        • jkr
          FE Addiction
          • 582
          From the technical data seems to be stronger from a 5 min epoxy.
          Is it bonds strong to epoxy?
          • dana
            • Mar 2010
            • 3660
            I've been using 30 min epoxy, But first I take strands of carbon fiber and cut it up so it resembles milled glass, and mix that in.
            • LarrysDrifter
              Big Booty Daddy
              • 3416
              Faster setting epoxy is weaker than longer setting.
              • dana
                • Mar 2010
                • 3660
                I realize this. But when used in bonding materials, it is quite strong. I never lay carbon or fiberglass with it, but all my motor mounts are done this way, and theyre very strong.
                • dana
                  • Mar 2010
                  • 3660
                  I think what's more important is the prep work where you glue.
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    Yep. Always sand both surfaces then clean them before epoxy. I also tack the mount with CA to hold it in place while I apply epoxy.
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 7708
                      Some good advice here :
                      Larry's 100% correct : Prep, Prep - ROUGH sand all mating surfaces, Tack in place with CA after trial alignment to keep shaft/collet mating perfectly, then add the bonding agent of your choice
                      I've done this to make a secure bond using JB :
                      Since then, I have gone to this :
                      http://www.westsystem.com/ss/g-flex-epoxy/
                      G/Flex is THE STUFF if you want things to never unstick. 2-3 hours to set and 24 hrs. to fully cure - Again, Larry is correct, faster setting is weaker than longer setting. I use G/Flex exclusively on all my "bulletproof builds"
                      • dana
                        • Mar 2010
                        • 3660
                        Reading the instructions and using glue for their intended purposes is the best idea. You can have success with even 5 minute epoxy if you prep well. I'm not suggesting it, but hey, we aren't gluing a dump truck to the underside of a bridge here... Lol
                        • properchopper
                          • 7708
                          When I built the first IB34 mono, I glued the rails/battery box in with 30 min. QuickBond epoxy. On a stupid/windy/choppy day I was goofing off and backflipped the boat. The "bonk" could be heard for miles (NO damage to the hull,'tho) The entire rail/motor/battery mount came unstuck . From that moment on it was G/Flex !!
                          • dana
                            • Mar 2010
                            • 3660
                            I can understand that...sorry to hear of your misfortune dood
                            • properchopper
                              • 7708
                              Thanks, but a "blessing in disguise". Thirty minute QuickBond epoxy is $11.99 ; G/Flex is $19.99. The extra $8 is well worth the money to insure no more stuff coming loose. Does make a build take longer while waiting for full cure, but I'm a total convert - 'specially since I build boats for customers and it helps me sleep at night knowing builds will (hopefully) stay built
