Leopard 4074 1400kv
  • sampit
    • Jul 2009
    • 466
    Leopard 4074 1400kv
    Just wondering,can the motor wires be cut shorter without affecting the windings on the leopards some motors it's ok, others you can't
    Could do with a tidy up. and this would help.
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • martin
    • 2881
    Dont shorten the wires their part of the windings, i have a Leopard 4074 motor in front of me with the end caps removed as im machining cooling slots in the caps. If you shorten them you then have to remove every trace of the insulating coating that is on the wires before you can solder connectors on. Martin.
    • sampit
      • Jul 2009
      • 466
      Thanks Martin I will just tuck them away.
      I have a 28mm Leopard with the ends slotted I'm sure it makes more power than the other one I had that had solid end caps.
      What you running your 40740 motor in?
      • martin
        • 2881
        Im not running the 4074 in anything yet just modding the end caps for when i do, i might put it in a JAE21 hydro that im going to build if i dont use a Leopard 3674. Yes i have some 28 series leopards one has the slots in the caps, i did hear that they may also be using more magnets in the new motors that may account for better performance over the older model but thats only what i heard somewhere.
