How to tell a bad motor?
  • Howard
    • Jun 2011
    • 269
    Other then a completely dead motor does anyone know how to tell if a motor is bad? I have one that revs extremely high at WOT (to high) Is this an indication of a bad motor also?
  • m4a1usr
    Fast Electric Addict
    • 2036
    Having a motor spin up beyond what you believe to be correct for its limits would require more information. It would be obvious to us if you stated that its a 4500kv motor and you were using a 4S for power. But to answer your question about how to tell is a motor is bad you have several options. One,.........you could spin the motor, chucked in a drill and spin it up, then measure the voltage on all three legs. Each of the three should measure an equal voltage. If you saw a large difference than the motor probably is bad. Second,.....Measure the resistance between the legs and than to the case. Unfortunately this requires you have a very high precision volt meter. Most folks are not going to own one. A fluke mod77 is not going to do it.
    John
    Change is the one Constant
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      John
      Man, I was good to go to test a few "suspicious" motors until I read the last sentence. My Fluke 77 is now hiding under the bed in shame
      • JIM MARCUM
        • Jun 2011
        • 775
        Tony, my Fluke 77 wants a date With yours. Can it come out & play?
        JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
        • m4a1usr
          • 2036
          Dont fret Tony. I dont have one either. My bench meter is an old Fluke 8020. But I have many from work of the "right" ones to use. My favorite is a HP 34401 but the HP 3458 is better. Problem in its massive. Like the size of a DVD player. Thank goodness I dont have to test motors often!
          John
          • G1ST
            • Dec 2010
            • 351
            I'm feeling "Fluke envy"
            My Radio Shack DMM is on the outside looking in.
            Greg
            • properchopper
              • 7708
              Greg
              Bro, don't feel bad; back in my "salad days" the only way I could test a brushed motor was to plug a wire into each nostril and comb my beard real fast
              • G1ST
                • Dec 2010
                • 351
                Tony, That is a visual that is going to be tough to shake.
                • G1ST
                  • Dec 2010
                  • 351
                  It there a test that I can perform with a standard multimeter that will tell me if a motor is going bad?
                  • properchopper
                    • 7708
                    step 1 : Attach meter leads to any two motor wires
                    step 2 : place nostril on motor endbell
                    step 3: inhale deeply through nose
                    step 4 : if memory of last encounter with nasty hooker is awakened, reject motor and flush nose (and memory) with good single-malt beveridge.
                    • G1ST
                      • Dec 2010
                      • 351
                      I gotta party with you!
