Another New hobbyking motor
  • 6BOOST
    • Sep 2011
    • 286
    #46
    I'm sure Ben isn't too concerned about the cost of a few motors, if it's not in his better business interests because HK sell them so much cheaper I'm sure he'll just stop carrying them. I personally have 2 of the TP's supplied by Ben and 4 of the same Kv motors from HK, so I can thrash the crap out of the HK versions, and even if I burn them up pushing them hard I'll have a good idea of what they can take before throwing the TP's in.
    6BOOST
    6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
      • 9481
      #47
      Soooo, I finally received my 1320 5692 today...
      Definately NOT a leopard clone. Different core & windings 4 SURE!!
      I haven't recieve my TP power motor yet to compare construction. I will follow up.
      This motor has 16 steps as opposed to 12 steps for leopard motors. On the inside of a 5692 Leopard there are 12 segments in the field plates. Most likely 99.99% sure the HK motors will have 16 but, it's too hard to count unless I open it up.
      For once i am stumped as to who makes these?? Or which brand it is derived from unles HK actually did request a factory to make their own brand.
      I will have to consult some other motor GURU's to see if this is a 4, 6 or even an 8 pole like a Neu 2210 I had & sold. Since it has 8mm shaft & more segments the rotor turns easier than my 5692 leo.
      The inner windings also stop shorter inside tha can at the rear like a 2210 Neu and unlike a leo 5692 with that looks like a longer stack. Winding wire or insulation on wire is different, much darker. Not sure what all this means. Because stack is shorter. weight is significantly lower at 815 grams compared to 880g.
      Specs are rated higher than a leo as per HK and side of box.
      Core resembles a Neu or Aqua craft UL1 motor in that looking from the outside in, it looks incased?? Maybe I will take it apart but, I don't really want to at this time.
      WIres that exit the rear vent holes should IMO be better insulated with lots more heat shrink or Med. to large size silicone fuel tubing. 4mm ID required and rear vent holes are approx. 9mm in diameter.
      I wish they would tell us how many poles it is so I don't fry an esc on testing!!!! LOL, will use cheapy esc on bench I guess.
      Definately not 2 poles though.
      More to come ! Merry X-mas!!!
      any more info Ray?
      thanks for the update on your findings...
      • 6BOOST
        • Sep 2011
        • 286
        #48
        Maybe everyone missed my post, the motors are made by TP power, and rebranded Turnigy. Nothing to find out. And they are a 4 pole motor.
        6BOOST
          • 9481
          #49
          any more info Ray?
          Looking forward to your testings Ray, on these Turnigy/TP motors
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #50
            Interesting for sure. I wouldn't hesitate to get one. Too bad they don't have them in 540kv.
            Higher temp epoxy and Japanese bearings are helpful in race conditions, but may not noticeably affect the performance for the bulk of the market.
            I'll release what I know once I get approval to do so. =)
            Meanwhile... HK has a habit of low cost until popular... With the 6.34 dollars to 1 was in our favor... I could use 600% markup just in currency conversion.
