Timing for a leopard 4074 on 6s
  • mikeochs
    • Nov 2011
    • 239
    Hey guys what is probably the best timing for a leopard 4074 1400kv runnin 6s through a seaking 180?
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    11 degrees is a good start if it a wye wind motor.
    • iamandrew
      • 576
      I had my 2200KV at 15 degrees but brought it back to 11, it ran a bit cooler, and i couldnt notice any difference in speed
      • mikeochs
        • Nov 2011
        • 239
        im runnin at 15 and this thing is as cold as it can be
        • mikeochs
          • Nov 2011
          • 239
          the manual of my seaking 180 says 6s should be 18.5 really?
          • Gimp
            I am the Stig
            • 547
            What timing should the a 2200kv run on 4s? I have my T180 set to 3.75* and runs as cool as a cucumber.
            -Fighter Cat Racing-
            • Boaterguy
              • 1779
              the cell count vs timing is not very useful, if you are running a high- pole count, 5S motor on 6S, you want lots of timing, if you are running a 2- pole, 8S motor on 6S, you wouldn't want high timing.
              • Marinetechal
                • Jan 2012
                • 29
                Yeah, I run 18.5 in my Pursuit...180 esc/ 4074-2150kv/x642/6s 5000mha 30c ballastic acceleration and speed but at heat cost and not a good runtime, guess we get what we pay for...hightiming=high temps!
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Cell count and pole count as usless when determing motor timing. It is all relative to the wind type of your specfic motor. D wind motors enjoy lower timing 0-7.5 degrees, Y winds enjoy higher timing 7.5-15 degrees.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    Way to much timing, and way to much voltage. IMHO your setup needs a whole lot of work, the amount of amps this setup is pulling matched with the excessive rpm your motor will not survive very long. Like I said JMHO. Please do not take offensive, just a heads up because the way your running it's not if something will blow, it's when....
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Marinetechal
                      • Jan 2012
                      • 29
                      Yes I realise I'm running on a knife's edge, so I have taken Keith Bradley's advise and detuned to 11 deg and 4s....
