can my leopard 4074 2200kv run 5s?
  • dana
    • Mar 2010
    • 3570
    just wondering….
  • Boaterguy
    • 1760
    44K rpm unloaded, that's alot.
    I'msure the motor would be able to take the voltage but would draw LOTS of amps and alot of heat would be created. Possibly a SAW setup.
    • CornelP
      • 745
      Works ok, I did a 6min race on a 5S Nanotech 4500mA (30" mono, 38mm prop). A bigger prop will get you to cooking temperature for anything longer than a saw straight...
      • dana
        • Mar 2010
        • 3570
        well on 4s i run m445. if i switch to an m440 will be better?
        • Rumdog
          • 6453
          Yeah, but it probably wont yield higher speed.
          • stadiumyamaha
            • 1284
            I wouldn't run it on 5s. I run 200kv motors on just about everything with a x642 and get low to mid fifties. Also try running 4s2p. Everything stays cooler and les amp draw.
              • 5554
              Here's mine on 5s.................checked temps after the run and they were in the normal range.
              • JIM MARCUM
                • 770
                Ran my Miss Geico with a Leopard 4074 2200at the Legg Lake SAWs this weekend (Oct 14-16) with 4S2P and hit 52 MPH on the first pass, and hit a turtle on the pass back. 5S2P would have been a bit heaver (and is over the P class limit), but might have put a bigger dent in the turtle. Score: Turtle 1; Miss Geico 0. JIM
                • JIM MARCUM
                  • 770
                  Ran my Miss Geico with a Leopard 4074 2200 at the Legg Lake SAWs this weekend (Oct 14-16) with 4S2P and hit 52 MPH on the first pass, and hit a turtle on the pass back. 5S2P would have been a bit heaver (and is over the P class limit), but might have put a bigger dent in the turtle. Score: Turtle 1; Miss Geico 0. JIM
                  • dana
                    • Mar 2010
                    • 3570
                    im only getting 50mph no matter what i do when running 4s2p. its a mean machine hull
                    • MORIDE
                      • 101
                      JIm, what prop are you running on your MG with the Leopard 4074 2200?
                      • JIM MARCUM
                        • 770
                        I was running an Octura X645. I bought the Miss GEICO hull only then the Pro Boat drive & strut. With a 4S29 config you can run a X648 x457 with my setup &a good speed controller. I used a SEAKING-180. Add more capacitors & you will have a better safety margin. Mounted a rudder w/H2O pickup on the Port sponson. It was on it's maiden run when on the return pass it hit a turtle 35" short of the SAW finish line, went airborne & crashed 10" from the finish lights . Impact ripped the rudder mounts off the sponson & the crash at 52+ (we'll never really know) impact split a 6" long section out of the Port sponson. See attached pics. I should have reinforced the starboard transon. But, they REALLY NEED to add more fiberglass on the hulls at the joint seams because a lot of guys have had their Miss GEICOs split open after minor impact crashes. ARE YOU LISTENING PRO BOAT!!! JIM
                        • MORIDE
                          • 101
                          Ouch!
                          Thanks for the reply. How do you add capacitors and can it be done on the Seaking 120? I am running stock motor SK 120 5S Gens Ace 40C 5000, detongued X642, I do run my strut lower that most here, but runs 47.1 MPH. I am just curious about the process of adding capacitors. I did like your offset rudder mod, did it help in the turns?
                          • JIM MARCUM
                            • 770
                            My SEAKING 180 was stock. You can buy caps here in the OSE parts section. I bought some but have not installed them. Check the forums on ESC & other elec links for installation help. Or just buy the 180. JIM
                            • ecoovert
                              • Aug 2011
                              • 242
                              Ran my Tacon 4074 2150kv. motor with a 180 amp esc. on 6s with an x442 prop with no problems. Temps never got above 119 degrees on my motor. Can't wait to try my 4082 setup.
