Castle cooling cans bigger nipples?
  • JPriami
    N4FOX
    • 1711
    Is there any way to have larger in & out nipples on the castle cooling cans for better flow?
    • 6057
    Saw "bigger nipples" so i had to look................they are the size they are for a reason, a steady medium flow helps to draw the heat out better than a fast flow........
    • Rumdog
      • 6667
      Not this conversation again...
      • JPriami
        N4FOX
        • 1711
        Ok thanks. Just wondered why my t180 esc and all the rest of the cooling system parts have larger holes then the castle cans are smaller. The stock red leopard cans even have bigger ones.
        I don't know if I buy the heat soaking in with slower water factor. I can see the point of it but not 100% sure of that. You turn your AC on high flow to cool faster & better you don't turn it on low to cool it better?
        Again I'm sure there have been test done and there maybe something I Haven't learned yet I'll freely admit that. Seems I keep learning from my mistakes. Lol
        • m4a1usr
          Fast Electric Addict
          • 2036
          Its possible. Just need to be able to drill and tap the jacket. Aeromarine sells the larger 10-32 90 deg nipples (yes that word Beavis!). They have an inside diameter thats larger then the ones that come stock. But I'm not sure its really necessary. My own feelings are the current design size is adequate. I guess I could do the calculations and end the debate. I designed mechanical refrigeration systems for years. Some even worked (joke). The math is very, very simple. Media specific heat, flow rate over area squared, and a delta t. Thats about all you need. Not too difficult.
          John
          Change is the one Constant
          • JPriami
            N4FOX
            • 1711
            Thanks again. Temps seem ok so I'll leave well enough alone I suppose.
