New Big Boy Motor
  • ReddyWatts
    • 1756
    Steven, if you get more of these motors in, I would like to test the 1200 kv. I have a 1200 KV Fiegao and a 1200 KV KB45 to compare it to on the lake. I will gladly pay for it.
    ReddyWatts fleet photo
    • SJFE
      • 4867
      What would you test it in MR Watts?
      • ReddyWatts
        • 1756
        I would replace the KB45 1200 kv in the M1 Supercat. I think it should handle the extra weight ok. It would be a good comparison using the same voltage, hull and controller while finding what the amps, prop and speed difference are in the three. I have already tried the Fiegao 1200 kv motor in this hull. This is a pretty versatile hull.
        • Steven Vaccaro
          Administrator
          • 8932
          In order to make it shine I think its going to need a hull running 8s. But I could be wrong.
          I want to run one in a 44" sniper on 8s to see how it goes.
          Steven Vaccaro
          • ReddyWatts
            • 1756
            That is what I am running the 1200 kv Fiegao and KB45 on. 8S
            • Steven Vaccaro
              Administrator
              • 8932
              Wow a boat that size with a feigao xl and 8s. What prop are you running. I didn't realize it could push that much.
              Steven Vaccaro
              • ReddyWatts
                • 1756
                Yep, it was running about 40. I posted a video on here somewhere.
                Here is the 1200kv Fiegao running on sport Tenergy batteries. 8S voltage
                This is the 1200kv KB45 with the same 8S setup on IB3600 cells.
                • Steven Vaccaro
                  Administrator
                  • 8932
                  Steven Vaccaro
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    Here is the 14XL Fiegao running on sport Tenergy batteries. 8S voltage
                    This is the KB45 with the same 8S setup.
                    http://www.rcflix.com/photopost/show...00&ppuser=3055
                    thanks for the links. i remember that now.
                    Steven Vaccaro
                    • ReddyWatts
                      • 1756
                      Y537/3 direct drive on both. Running the smaller prop is like running them on a trans allowing higher rpm and speed.
                      • ReddyWatts
                        • 1756
                        FeCalc says the 1200kv motor on 8S with a X640 prop will use 88 amps and run over 50mph. 2550 Watts. 31000rpm
                        The Y537/3 will use 60 amps at over 50 mph, if this is truly a 60 amp max motor. 1800 Watts. 32000 rpm
                        I can try this motor with these props on 8S in the 34" supercat hull for the best speed and keeping the amps low.
                        It will turn the larger props on 6S and run in the 40's for larger hulls.
                        Thats my 2 cents worth.
                        • SJFE
                          • 4867
                          Mr Watts...are you saying the smaller S-Cat hull such as mine or the M-cat?
                          • ReddyWatts
                            • 1756
                            I have the 34" M-supercat.
                            Thanks, I corrected the previous post, It was misleading.
                            • SJFE
                              • 4867
                              Ok my S-Cat is only 27x10
