Installed a castle 1800kv motor and turnigy 125 amp esc, im running a x642 and id like to know where this set up would be best to run on timming wise and battery maxx, i took it for a test run on 4s then 5s then 6s and got some high temps on esc, couldnt open her up due to choppy water, im getting 125 degrees at the esc and water is feezing cold, motor and battery are cold, dont wanna burn anything up. any advice would be appricated
Castle 1800kv in geico
You runnin' the 1512 or 1518?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Ran the same motor in mine on 6s with no trouble. You might be a little aggressive on your prop selection. I was running a m440.FE BOATING: Less like a hobby and more like an addiction!
that's a good pointOriginally posted by blackcat26 View PostRan the same motor in mine on 6s with no trouble. You might be a little aggressive on your prop selection. I was running a m440.
almost 40,000rpms
