Feigao faster than castle?? what the...........
  • keithbradley
    • 3671
    Originally posted by 6sHyper View Post
    well i will check the power analyzer next time out, i dont think its capable of recording the voltage drop though.
    as for a 6s2p setup, the only way feasable would be to run 4 3cells. as 2 6cells will be too thick to fit in, would need to run 2 up each side back to front. Has anyone done a 6s2p setup in an apparition and have pics of teh layout?? must be a real tight fit!
    I have one here with 4 3s pack in it right now...no problem.
    www.keithbradleyboats.com
    • 6sHyper
      <<<Surfs up!
      • Jan 2011
      • 640
      cool post a pic i'd love to see it, what kinda speeds you get? setup? etc...........
      heres mine, and a sneak at my soon to run 6s Red evo
      • keithbradley
        • 3671
        Keith, I'm thinking the 1520 1600kv will be faster too, just a hunch................... we will see. whats the fastest anyone on here has got an apparition or similar hull up to??
        Is it weird that all i care about is going faster?? lol For whatever reason the need to go faster is all i seem to care about when it comes to boats! I think i need to build a rigger!!!
        I ran a 1520 on 6s2p in my bittburger cat. It ran VERY well with a s220 prop. It turned a s225 at that rpm but pulled 209A doing so. I also perfectly landed a backflip that covered a pretty good patch of lake with that boat...
        My internet search for the fastest cat ended here...75mph:
        • 6sHyper
          <<<Surfs up!
          • Jan 2011
          • 640
          lol
          • Alexgar
            • Aug 2009
            • 3701
            i dont think a 1520 will fit my cc1515 touches the hatch
            • keithbradley
              • 3671
              Mine's actually a 32" Fightercat, which is a little different, but very similar in size. As far as speed, I dunno, its not finished yet. Maybe 61.4? I have changed my plans (for the _th time now) and decided to run it on 8s1p. Just need to sell the two escs I have in the swap shop.
                Yes keith i have GPS'd it at 61.3 exactly 3 times on the x442 with the Feigao, and 58.7 twice on an m440.
                Sorry, I find the above impossible to believe. The OP wants an answer - then he disses all the responses. Bye.
                • Alexgar
                  • Aug 2009
                  • 3701
                  yeah keith i saw the thread where you bought them i was tempted to i need to order a couple thing from there and was thinking of grebbing a small outrunner to play with in a 21" saw vee hull
                  • 6sHyper
                    <<<Surfs up!
                    • Jan 2011
                    • 640
                    keith do those come with the carbon fibre inside or did you do that?? looks really cool.
                    and IDK what fluid is talking about, i guess he thinks its impossible to get the same readings multiple times?? never said it was all in a row or that there wasn't other readings slightly off, and where did i diss responses?? lol
                    • 6sHyper
                      <<<Surfs up!
                      • Jan 2011
                      • 640
                      Alexgar i think i read somewhere that the newer apparitions sold had slightly more hatch clearance?? not sure, i guess i will find out soon if the 1520 fits, will let you know, i hope soooo.
                      • keithbradley
                        • 3671
                        I did the carbon fiber. The same company sells some hulls that are ALL carbon fiber though...theyre pretty hot
                        If you do run the 1520 in there, you may want to think about switching mounts. That motor is quite a bit heavier and longer...you may run into problems with the 2 bolt mount.
