am i right in thinking the timming on the leopard 4082 1450kv 4d should be between 0/10 or low timming setting?
timing for leopard 4082 1450kv 4d motor?
Reference Neu Motors:
Use low (0-10 degrees)or medium(10-15 degrees) advance settings for “Y” wind motors and low (0-10 degrees) advance settings for “D” wind versions.
Timing ?
Hope you can help with similar question on Leopard made for Tacon 4 pole motor.Here is the # of the 2 motors I am using for a cat. LBP 2860 B/4D 2550 kv.I am running both on 3s and need to know if I should use the low timing like all the rest of the D motors.The timing on my 120a ESCs can be at 0,3.75,7.5,11.25,etc.The data sheet has the exact same specs as LBP 2860 4D 2550kv.Originally posted by Diesel6401 View PostReference Neu Motors:
That is also a "D" wind motor, your seaking timing is default at 15. Turn the timing down some. Try 3.75 or 7.5 make a note which works better.Originally posted by Igoreski View PostHope you can help with similar question on Leopard made for Tacon 4 pole motor.Here is the # of the 2 motors I am using for a cat. LBP 2860 B/4D 2550 kv.I am running both on 3s and need to know if I should use the low timing like all the rest of the D motors.The timing on my 120a ESCs can be at 0,3.75,7.5,11.25,etc.The data sheet has the exact same specs as LBP 2860 4D 2550kv.
Least amount of amp draw and heat would be best...Originally posted by Igoreski View PostThanks I had it at 7.5 for my 2 pole Feigao 380XLs which might have been wrong.Should I look for which draws less amps,less heat or most rpms.
7.5 is a good starting point, maybe try dropping down one and see how it works out for ya.
