leopard 4082
  • MARKY C
    • 37
    leopard 4082
    can someone answer this for me would the leopard 4082 1500kv get higher top speed than the 1450kv 4082 and what speeds would they make using turnigy 180amp esc using x445 prop on 2x3's 5000mah 40/50c in series 6's
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    On a 6s voltage set up,the 1500kv will be 33,300rpm.
    The 1450kv will be 32,190rpm.Thats only 1,110rpm difference.It might not even be noticable.I run the 1500kv version and love it.It has great top speed and low temps.
      The 1500 Kv motor is a 2Y while the 1450 Kv motor is a 4D. The 2Y wind will be slightly more efficient based on the Io and RM values, but the differences are small. As Larry said, you probably would not notice a difference in performance, but I'd get the 1500 Kv motor.
      • Karfrik
        • Jun 2009
        • 1248
        sorry to chime on this thread,but what would you guys put on a 37" Aeromarine Sport hydro to be run on 6S and t180 esc? a 4082 or a 4074? what prop do you guys suggest?...........
        Thanks,Albert
        • MARKY C
          • 37
          i would use the 4082 with a 445 prop with the 1500kv or the 1450kv motor if running on 6s with a 37'' hull the 4074 is a bit small
          • LarrysDrifter
            Big Booty Daddy
            • 3416
            You would?
            • m4a1usr
              Fast Electric Addict
              • 2036
              Thanks,Albert
              Neither of those motors are decent choices for that 37" hull. Maybe a 5682 2Y as its a larger diameter can and has more power then a 4082. The CC/Neu 1717 would work, and better then either the 4074/4082, plus its also only $70! To get your hull rock'n you should look at a 1521 or a 2250. If budget is tight get the 1717.
              John
              Change is the one Constant
              • Make-a-Wake
                FE Rules!
                • 6057
                John
                Did you mean a 1527, which is more on par with a 1717.................a 1717 is more powerful than a 1521. Never heard of a 2250..........
                • m4a1usr
                  • 2036
                  Lehner.
                  John
                  • Karfrik
                    • Jun 2009
                    • 1248
                    John
                    Where can i get the 1717 for that price?.....
                    • m4a1usr
                      • 2036
                      Here you go! Good motors too! I bet the sale is going to be ending in the not too distant future. Might want to get 2. http://www.castlecreations.com/promo...clearance.html
                      John
                      • Karfrik
                        • Jun 2009
                        • 1248
                        Thanks!!!......Al
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          Lehner.
                          John
                          Oh...........sorry, i havent delved into the high end stuff yet........heard they are pretty much top notch.
                          • scoota
                            FE DOWN UNDER
                            • Dec 2008
                            • 439
                            For those who are interessted i did some data logging with the 4082 in a DF33 on 6s & its pretty much on par with a NEU 1521 , in size & power . i dont think it wouuld be big enough for a 37" hull, JMO , well not if your after a good top speed ...
                            Running a X 648 prop
                            Peak AMPS - 193
                            Peak WATTS - 3691 / 4.94 Horse power
                            GPS - 62 mph
                            UL1- 1515 castle/neu / 240 swordfish
                            SV27- with UL1 running gear
                            33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
                            • richt
                              • Dec 2010
                              • 67
                              i want to see if you can halp me i have a 35 in mono will the 4082 1450kv with a 240hv esc on 6s with a x445. i want to get it up to 60 mph can you let me know.
