Leopard 3674 Bearings
    • 7990
    I haven't opened my new Leopard 3674s, what size bearing is required for replacement. I assume the bearings for a 540 Feigao would work - but someone must know the specifics. Thanks!
    • 7990
    Anyone? Bueller? Anyone?
    • Jeff Wohlt
      • 2716
      Do you not have a digi mic gauge? Would have thought someone would know but sorry I do not. I have some of those coming but can't answer you yet.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Alexgar
        • Aug 2009
        • 3522
        there is a part number on most bearings, type it here and they are pretty cheap
        Buy premium ball bearings online from VXB.com - your trusted bearing supplier and distributor. Explore a wide selection of bearings at wholesale prices with same-day shipping and next-day delivery. Precision, speed, and reliability delivered fast.
          • 7990
          I have plenty of precision measuring devices but they do me no good unless I open the motor and remove a bearing to measure. No part numbers are visible from the outside of the motor. If no one knows the size then I'll have to open the motor, which I really didn't want to do until I have the bearings. Opening the motor flat-spots the rear bearing and ruins it so the motor can't be run until I have new bearings. Thanks for the help guys!
            • 9438
            Hey, chill...
            They bearings in the 4074 motors are just fine and don't need upgrading. What makes you think the 3674 motors need upgraded bearings?
            Most likely the same as the 4074 motors, 5mm x 16mm x 5mm but, I'm not 100% sure.
            Why not run it the way it is?
            • AlanN
              • Mar 2008
              • 334
              Hey Jay,
              Sounds like you had better just get out the can opener!
              Guys, Jay knows what he is doing. He just wanted a direct answer. He's prob looking to replace them with a higher grade for saws or just cuz that's how he wants it.
              • m4a1usr
                Fast Electric Addict
                • 2032
                Most of the 540 cans use 5 x 11 x 5mm size bearings. Thats what I have found with the Nemesis, Hacker, Feigao and Keda's over the years. But I dont own any Leopard 36mm cans so I cant say with any confidence.
                John
                Change is the one Constant
                • Himalaya
                  • Apr 2009
                  • 251
                  Leopard used 5x13mm bearings in the earlier batches of their 36 and 40 series motors. They then just decided to go bigger to 5x16mm. Now sure what revision you got so you may have to open it to have a look. 3mm is quite some diff in appearance, pretty easy to tell even by naked eyes.
                    • 9438
                    I was guessing on bearing size Mr. Himalaya, just to let you know...
                      • 7990
                      Thanks guys, looks like the can opener it is!
                      • norbique
                        • 356
                        opening the can?
                        can someone tell me what's the proper procedure to open up a leopard motor?
                        I unscrewed the 3 screws, but the endbell is still rock solid on. Do I have to hammer it out? :)
                        Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
                        - Mark Twain
                          • 9438
                          On a solid piece of hardwood on a table you should be able to carefully tap the motor shaft on the wood with the motor in hand to break the press fit or light CA glue. One seal is ajar, tap lighter until the end pops out of the case.
                          • norbique
                            • 356
                            Thanks I succeded taking it apart in the meantime. Did a bit differently though. I held the motor in hand, but used a copper hammer to hit the shaft and it worked.
                            Next question: where do you get your replacement bearings from? And is the ceramic bearing hype worth the extra $$?
                            - Mark Twain
                              • 9438
                              I buy my bearings and bearings for a buddy from a local guy. He's older and crusty and says "go ahead and spend extra on them if you want but, these are better in the long run...." I think I paid $10 each for some Japanese VXB bearings.
                              Thats thats pretty much all he sells is bearings.
                              If they were that great maybe Lehner after decades would be putting them in their motors. Wish I could get some of those bearings easy...
