Leopard 5692 Motor comparison
  • Diegoboy
    • Mar 2007
    • 7443
    Check out the size of this Leopard 5692 Motor, in comparison to a Neu 2215. Wow!
    Has anyone seen any performance stats to compare the two?
  • tth
    • Apr 2008
    • 1600
    Thanks Danny. I have been wanting to see a comparison. I have a Leopard 730kv on the way. I am going to run it on 10s in a 40" Insane Cat. You must have some pull to get a water jacket for that baby.......wish I had those connections!!!
    • Diegoboy
      • Mar 2007
      • 7443
      I found that pic in an extensive google search. I wish I had both motors to take this pic, let alone the jacket!
      • tth
        • Apr 2008
        • 1600
        Thats some serious horsepower sitting right there. I wish I had them both at my disposal too!!!
        • TotalPackage
          • 622
          So T would you run the 730 kv @ 10 s? why not go with the 1000 plus kv and run 6s? Not disputing you just curious about your choice in the hydro. Im considering the change from the screamer to the leopard in my 1/8th. I was just wondering about what setup would be best.
          • tth
            • Apr 2008
            • 1600
            I prefer to use high voltage setups. Easier on equipment and longer runtimes . Don't get me wrong tho sometimes on my smaller hydros and riggers I run high kv motors with low voltage but reliability is not there. On the setup you suggested with the 1000kv motor on 6s that just wouldn't work. The 1390kv motor would be better on 6s. 1000kv is better suited for 7s-8s depending on hull type. My Leopard is going in a Gen1 Insane Cat, it'll draw way more amps than a hydro that's for sure.
              • 9481
              One of those motors would look great in my Baja 5B!
              • TotalPackage
                • 622
                theres a 2215 on ebay for 400 dollars
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  I want to know where that jacket came from!?
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    The jacket came from OSE. I will gave more very soon.
                    Steven Vaccaro
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      That should say "have" more. I can't edit posts on this not so smart, smart phone. :-)
                      Steven Vaccaro
                      • alvinsmith75
                        • 635
                        HAHAHAHA Nice save! You don't want to give them away!!!!!!!!!!!!!
                        • tth
                          • Apr 2008
                          • 1600
                          Jeff Wohlt made me a sweet @$$ coupler for the Leopard I just got in. Perfect fit might I add. I have never been a big fan of set screw couplers but a little flat spot on the flexshaft will do just fine. I will be putting in on a .250 drive line so there is nothing available at the present but I did call Octura and put in a good word as per Steven. It may help to speed up the process. In the meantime this one is doing a good job.
                          • sailr
                            • 7128
                            Save one for me!
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                            • gerardobrandao
                              • Mar 2008
                              • 166
                              Leopard 5692
                              Hello TTH
                              Have you already spinned the motor with the speed controller?
                              I say this beacause i have one, and the schulze 32 200 didn´t drive it correctly past 3/4 trohttle...It starts stuttering at this throttle range.....
                              I received now a new YGE 160 NAVY HV, and it drives it, but only at 0º timming
                              Have you already tried that,an input from you would be very valuable!
                              Best Regards
