leopard vs neu???
  • Steven Vaccaro
    Administrator
    • 8932
    Originally posted by vasy View Post
    Did you also order cooling jackets?
    Kinda bad if you get motors then have to wait 2 more month for the jackets to arrive.
    Do you mean Leopard sells jackets? If thats the case I didnt know.
    We have to have the 56mm motors in our possession before we can design and test jackets. It takes time.
    I hope to have more 40mm jackets in a couple of weeks.
    Steven Vaccaro
    • bustitup
      • 3072
      water jackets are fairley easy to make.....just find a piece of pvc pipe with an outside diameter thats about 1/8" bigger than the outside diameter of the motor......wrap carbon fiber cloth around around the pvc pipe about 4 or 5 times and clear epoxy it.......wrap the pvc pipe with seran wrap first..then just take the finish product to plumbing supply house and get two o-rings to match
      http://forums.offshoreelectrics.com/...=kb45+bearings
      • gerardobrandao
        • Mar 2008
        • 166
        Leopard Vs NEU
        Hello
        I have a Leopard LB5692 1090KV, it´s a 2Y winding.
        The first thing i made was opening it up, in order to see the interior.......
        The quality seems very good,just like craftmanship.
        All is made by CNC machines,wich is normal in chinese countries....i already visited a factory that had more then 50 CNC lathes working day and night with automatic feeders.....
        The stator laminations are 0,2mm, the cross section of the cooper cable is considerable,the same as mine 1527 1.5D.
        The rotor seems well balanced, and is wrap around carbon fiber.
        But all go to this.
        Cooper cable quality
        Magneth quality
        Design quality
        This is what changes efficiency from 80 to 95%
        I still couldn´t test it because it doesn´t work with mine schultze 32.200WK
        Regards
        • gerardobrandao
          • Mar 2008
          • 166
          i meant east side countries....Sorry
          • vasy
            • Dec 2009
            • 348
            Regards
            What does this mean? what is schultze 32.200WK?
            • Diesel6401
              Memento Vivere
              • 4391
              That's his esc. Schultze top knotch stuff... http://www.schulze-elektronik-gmbh.com/fut-xxl-e.htm
              - Diesel's Youtube
              - Diesel's Fleet
                Schulze ESC's have a hard time with some motors...
                The 1080Kv on 8S will be nice, 32,000 rpm unloaded. Good for my 40" mono.
                • U.L. HYDRO DRIVER ICE
                  • Apr 2008
                  • 270
                  Would the 40/74 2200kv leopard work in 1/10 scale hydro turning left prop447r on
                  one 4s pack 5000m 40c castle 240lv . I was going to use it for racing
                  • gerardobrandao
                    • Mar 2008
                    • 166
                    leopard
                    I intend to use the 1090KV with 10S in mine rigger...The same as using a NEU2215 1.5y with 10S.....
                    Regards
                    • vasy
                      • Dec 2009
                      • 348
                      I've tried 445, it worked well, on 5000mah I get about 2 minutes runtime at WOT in a mono. So maybe 447 will be ok as well. Hydro should load the prop less and with 445 the motor comes in cold anyway, so extra load should be ok.
