Leopard Hobby 4-Pole CC/Neu Clones
  • Xfactor
    • 874
    #46
    The only difference is probably the custom options available but also when u handbuil you can bet that his specs are dead on. With the manufactured stuff its probably +/- 5 %. I run turnigy too love it but ist it better than a benz controller???180 amps is alot so to claim it u better be able to do it. But most manufactures rate thier stuff @ 90 percent of what it will do.For good reason ;we wanna take everything to its limits.One need to also consider this . If you wanna pull 60 amps continuous u better buy a 120 amp continuous esc over estimate always. In this hobby overkill is better.I tell you one thing Id buy turnigy before castle i bet you that cause those guys lied in my opinion on the screamer thread. Any esc maker in the world knows that firmware updates alone will not aways fix a problem .They knew that when they said it.
    • Xfactor
      • 874
      #47
      I just want to see the 52 red run.
      • questtek
        • 648
        #48
        Originally posted by Xfactor View Post
        If you can keep those motors dry u might have something there.No drag. Y not make them vector thrusters if thats the case . The one problem I see is when the boats up on step are the pods still gonna be dragging in the water? and how will that affect handling?
        This build or project is totally experimental. The goal is to make it as simple as possible. I have had great success steering large aeromarine avenger cats using such a dual motor set up but only at lower speeds. I want to try to eliminate the complexity of servos or ducted thrusters. I have tried these motors with large jacuzzi jet drives and they work great but the drive is 4 times the cost of the Leopard motor!
        One other factor is that the interior of the cat is most important for my specific application since it is loaded with electronic equipment including a small Pentium computer with solid state drive and three independent wireless video systems. Keeping the motor outside means only batteries and the ESC's inside whose location is very flexible.
        This a works in progress and it might be best after all to put the motors on the inside of the outer sponsons with a short, direct drive and again do steering by individual motor speed and direction. You certainly are right on the drag and I do not expect this to be any type of SAW record holder!
        • questtek
          • 648
          #49
          who will be first?
          Here is a Leopard 220O KV with water cooling in the motor mount only and fan cooling on the case. I run a complete Eagle Tree system on it with GPS. The boat is not tuned and in I run almost exclusively carbon props. However Josh gave be a three bladed polished prop and here is the Eagle Tree of the first run. 50 MPH is a non-set up condition is a good first start for this mono with my limited knowledge.
          • Rumdog
            • 6667
            #50
            I wonder if the OSE water jackets for the castle/Neu motors will fit. I'm guessing that they will.
            • Rumdog
              • 6667
              #51
              Otherwise, it may have the same can O.D. as a Neu 1515.
              • crabstick
                • 955
                #52
                Originally posted by questtek View Post
                Here is a Leopard 220O KV with water cooling in the motor mount onlyand fan cooling on the case. I run a complete Eagle Tree system on it with GPS. The boat is not tuned and in I run almost exclusively carbon props. However Josh gave be a three bladed polished prop and here is the Eagle Tree of the first run. 50 MPH is a non-set up condition is a good first start for this mono with my limited knowledge.
                What boat is that ? the pursuit from Hobbyking?
                Matt.
                www.rcboats.co.nz
                • Diesel6401
                  Memento Vivere
                  • 4391
                  #53
                  I'm really interested in the 36-74 1290kv or 1790kv. http://www.leopardhobby.com/product/...ionID=01020211
                  Just can't find a anywhere to place an order for these motors.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • questtek
                    • 648
                    #54
                    Almost....The China factory I deal with makes the Pursuit and Genesis. However the specific ones they sell to Hobby King are different. They actually have 3 or 4 slightly different models on each of the boats. The boat in the picture is one I bought in China in person and hand carried back as a bare hull with drive hardware only.
                    • questtek
                      • 648
                      #55
                      I gave one of these 2200KV Leopard motors to MarkF for testing on the new Insane Hydro. We ran it with NO type of cooling at all, but only for short, fast runs. MarkF said he had a water jacket for it so hopefully he will read this and add his comment as to the specific type of water jacket he was thinking of putting on it. I think he said he got the jacket from OSE.
                        • 9481
                        #56
                        Thanks for the pictures!
                        are those equal to a 1515 in their size?
                        I'm getting really jazed by the possibilities of these motors
                        • questtek
                          • 648
                          #57
                          Brushless Motors Neu and Leopard:
                          Neu 1515 1Y
                          Max V 27 vdc
                          No load amps 2.5
                          Resistance 0.006
                          Max RPM 60,000
                          Shaft dia 5 mm
                          Weight 340 grams
                          Length 68.6 mm
                          RPM/Volt 2200, 4-pole
                          The Leopard brushless motors I am currently evaluating
                          Current rating 120 A continuous. (I have measured 160 amps via my Eagle Tree on speed runs)
                          Max V 22.2 vdc
                          Resistance 0.0062
                          Max RPM 50,000 with standard NGK Japanese bearings
                          Shaft dia 5 mm.
                          Weight 374 grams
                          Length 73.8 mm
                          RPM/volt 2200, 4-pole
                          dia 40 mm L=75mm
                            • 9481
                            #58
                            Neu 1515 1Y
                            Max V 27 vdc
                            No load amps 2.5
                            Resistance 0.006
                            Max RPM 60,000
                            Shaft dia 5 mm
                            Weight 340 grams
                            Length 68.6 mm
                            Max V 22.2 vdc
                            Resistance 0.0062
                            Shaft dia 5 mm.
                            Weight 374 grams
                            Length 73.8 mm
                            dia 40 mm L=75mm
                            How could we go wrong?
                            looks like I need to order 2 of these bad boys for my Twin powered Hydro
                            • sailr
                              • 7128
                              #59
                              Closed loop?
                              Theyll buy it if it gurantees some placed finishes.Also Im gonna say it again when people on here start trying closed loop i really think the amp draws will come down and we can extract more out of the sport.
                              Mini Cat Racing USA
                              www.minicatracingusa.com
                              • old guy
                                • 710
                                #60
                                I have a little of every thing and a made in the USA 240 that is smoked after 3 passes and only got to 90 in temp we will see if they will warranty it lol. I would just like to say this if it was not for or knockoffs a lot of poeple would not be able to do FE becouse of the price of the parts just my 2 cents. and I hope they will give me a new 240 ESC or next time I will buy chines.
