the hpi tork 2200 or castle 2200 kv would be perfect on 4-5s but for 6s I don't know, probably the 1515 1.5y, I have it in the mean machine and even tried it in the df35" with a 43 prop and runs great never heats up
540 XL vs 580 L vs neu castle vs neu
http://www.rcfastboats.com/
both are perfect for 6s you will never have any problem, the 1515 will be OKTwin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
The 1515 are great in mono's about 33" http://www.youtube.com/watch?v=EXhwHUnK-ec
1515 1y on 4s set up run
To me the 1515 will be a borderline motor for the Df33, I would personally get the 1521 1Y or the Neu/Castle 1520 if you plan to use 6s. I know others have run the 1515 but I think a little larger can would be better.Team Liquid Dash
What was your setup with the 580l. I will be running one in a 31" mono on 4s.If all of your wishes are granted, many of your dreams will be destroyed!
I disagree Raydee , hey that rhymes !! Anyway have tried 1521, 1527 and 1515 in a DF hull. Admitadley on 4s but for my money it is the 1515. If your hull is set up well and the hull blue printed nice and sharp it is the motor for me. Good run times, in circuit trim lap times as good or better and less amp draw
You should have tried 6s and awakened that 1521! Some of us already played with the 1515 in the DF33 and the winner was a 1521. Hands down.Originally posted by andym View PostI disagree Raydee , hey that rhymes !! Anyway have tried 1521, 1527 and 1515 in a DF hull. Admitadley on 4s but for my money it is the 1515. If your hull is set up well and the hull blue printed nice and sharp it is the motor for me. Good run times, in circuit trim lap times as good or better and less amp draw
JohnChange is the one Constant
The 1515 1Y is a fantastic motor for a 33" mono on 4S.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
I am actually thinking about buying the 36" version and selling my 33" version. I think the 1521 1.5D might be a bit much for the 33" version. Either that OR I just need to set mine up better
Team Liquid Dash
The neu runs MUCH cooler than the feigao, so I can turn a larger prop and get more performance out of it. But on same size (smaller) prop they seem to run pretty much the same with regards to speed.Originally posted by Make-a-Wake View PostHey Chief..............since you have ran both, how does the 1515(40 x 68mm) compare to an XL Feigao(36x74mm) performance-wise?
-Chief
