Anyone ever seen this Neu motor run ?
  • Xcesive8
    • Jul 2009
    • 439
    Hi all,
    Possibly looking at changing over a few Gas boats to FE.
    Was wondering if anyone has a link to a video or a thread with info on one of these Neu 1900zr drop in zenoah replacements?
    The drop in Zenoah replacement
    Used w/ Castle HV 120 ESC
    5.1 hp peak @ 17300
    1.8 Nm torque @ 17300
    18000+ rpm under load typically 4+hp (10S)
    60-70mm props
    80-95 kph with 5 – 3 minute run respectively
    Use w/ 8mm-1/4” collet
    $AU 340.00
    Info courtesy of Fastelectrics.com
    Last edited by Xcesive8; 01-19-2010, 11:46 PM. Reason: This is exactly how first post was!!!!
  • Jeepers
    • May 2007
    • 2050
    No.. but I was wondering about when I seen it in that ad.
    • Steven Vaccaro
      Administrator
      • 8932
      It sounds like a good sport setup. But for racing I would run a higher rpm motor. I've tried running high torque/lower rpms motors and can't get the efficiency I would like for racing.
      Steven Vaccaro
      • Xcesive8
        • Jul 2009
        • 439
        Yes well ive contemplated buying 2x Neu 2230 1Y's and running 12s a side..
        That will give me the low 32k rpm.
        Not sure if ill need that much motor, i could maybe get away with 2215's ( each side ) although im looking for most run time i can since ill be running an offshore class against other gas boats.
        Its a CT03 hull, im goin to need something decent to get it moving as that size is starting to get a lil on the heavy side..
        What motors does anyone reccomend with CT03? 67 inch.
        I want a solid 5mins with reasonable speed.
        • raptor347
          • Jul 2007
          • 1177
          It's an 8 pole 19 series. I just don't know what length or wind. My guess would be a 1920/1y.
          I have a 1917/.5y that Steve wound for me. It's destined for a Q hydro.
          The 19XX series has some serious potential, and a few limitations.
          Brian "Snowman" Buaas
          Team Castle Creations
          NAMBA FE Chairman
          • TRUCKPULL
            • 3293
            Originally posted by Xcesive8 View Post
            Hi all,
            I cant find nothing and cant drop the coin into one until i see one go..
            5.1 hp peak @ 17300
            60-70mm props
            $AU 340.00
            At 18000 RPM on 10S = about 485 KV
            May be a little low on the KV
            • NitroVal
              • Jun 2009
              • 423
              Why just a motor? Why not motorssssss?
              The RTR Nightmare- Electric King of Shaves
              Now with 540s- 62mph
              New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
              • sailr
                • 7128
                Around 800KV would be better!
                Mini Cat Racing USA
                www.minicatracingusa.com
                • Xcesive8
                  • Jul 2009
                  • 439
                  Im sorry i dont follow?
                  Ive got apostrophes and " S " after everything lol.
                  2230 1y's
                  2215's
                  • TRUCKPULL
                    • 3293
                    The "S" at the end of the motor # stands for Smooth can,instead of a Ribbed can.
                    Larry
                    • Xcesive8
                      • Jul 2009
                      • 439
                      Larry
                      Oh ok,
                      Well so theres no more confusion, ive put 2x and in bold[/
                      I guess i thought everyone would no what im talking about when ive mentioned a 67 inch hull. Do people actually bother running a single in a hull at nearly 70 inches?
                      Anyway, i hope its now not misleading.
                      Thanks for eveyones input so far
                      • TRUCKPULL
                        • 3293
                        ""If there ok, i wil run 2 of them in my CT03.""
                        First question CT03 ?
                        Mono?
                        CAT?
                        Hydro?
                        Rigger?
                        A pic would be nice.
                        Larry
                        • Xcesive8
                          • Jul 2009
                          • 439
                          Mines in transit at the moment..
                          But they look like this >
                          MHZ makethem, HPR do a very similar hull ( CT04 ).
                          There a scale of a Tencara hull, (MARITIMO and heaps of other race teams have used them)
                          Picture taken from Speedtoy.com
                          • ozzie-crawl
                            • Sep 2008
                            • 2943
                            is it just me or what
                            see advice from people "kv is to low" and such then the question "whats a ct03"
                            how do people give advice on whats what when they dont even know what the boat is.
                            did anyone read the direct zenoah replacment in the first post
                            • nobbiworld
                              • 170
                              Ryan, I am building a CT03 at the present moment. It will be powered by 2 of these motors(1917 1y).Running 12s a side at 485kv. I am hoping for appox 50mph and 4 minute running time. We will be back at the Brisbane club this weekend if you are interested. Hope to see you than.
