Castle Hydra 120A vs Seaking (hobbywing) 180A
  • MonsterMaxx
    • Jun 2009
    • 50
    I'm getting pretty close to having made all the decisions for upgrading the Titan 29" and the UL1 to run 6s30c2650 packs in a 6s2p configuration.
    Will be using the fiegao 13xl motors and will prop them somewhere around 50-60 amps = 1100-1300 watts.
    Trying to decide between the hobbywing 180A esc and the Castle 120A and I need two of them.
    The hobbywing is a lot less $ and has more headroom in case I ever want to use these in something else but it does weigh more and is a 'cheap chinese' product - who I'm never thrilled with supporting, then again, the Castle stuff is probably made in china anyway so what's the diff.
    So, for those of you who have used both of these, which would you choose? Would you spend the extra $100+ for the castle or....
    Also, not only is the castle quite a bit more $, but it's BEC won't work on 6s, so I have to add a waterproof BEC too.
    money is tight around here, no question about that, the plan already has me spending more than I'd ever planned on.
    17
    Castle Hydra 120A
    0%
    0%
    12
    Other, see below
    0%
    4
    5 cars, 9 trucks, 2 scale, 1 crawler, 2 boats, 8 helis, 3 planes, 1 jet, a hydralic endloader, and that’s just the ones that are rtr or nearly so, not even counting the ones in a bucket, ugh, I got it bad.
  • domwilson
    • 4411
    Have you considered these... http://www.himodel.com/electric/HiMo...-200A-BEC.html
    Government Moto:
    • MonsterMaxx
      • Jun 2009
      • 50
      Originally posted by domwilson View Post
      Cost is nice, but it says it's not for boats. Granted I could add water cooling to it, but pretty sure I want one that if it gets wet I don't have junk. Then again, I guess I could give it a conformal coating. hmm, something to consider
      Good suggestion. Keep 'em coming.
      • Flying Scotsman
        Fast Electric Adict!
        • 5195
        If, you are going to run 6S2P...neither. You will need a high voltage ESC.
        Douggie
        • calcagno45
          • Mar 2008
          • 1050
          those are sketchy tho. I know a lot have used them with mixed results. I had 2 of the HiModels go out, 1 with little use, 1 ran for a long time!
          • bustitup
            • 3072
            I can give you a good deal on this and will handle your need easy
            its brand new
            Only reason i am selling is because i need much more amps with HV
            this is a HV controller that will handle 12s
            • MonsterMaxx
              • Jun 2009
              • 50
              Douggie
              I think you need to figure that again Douggie. 6s2p means I'm not running them in series, I'm running them in parallel. Still 6s voltage 22.2. The mah does double, but not the voltage.
              If I was running them in series, it's be 12s1p...and that's what I do in my 600e heli. Originally I wanted to do this in the boats too, but everyone convinced me that it's excessive. After doing a price workout, the cost would be nearly double to run these in series for 12s, plus motor selection gets pretty slim to get the right KV.
              The decision to stay with 6s came down to a wallet decision.
              • domwilson
                • 4411
                Hello there,
                There are a few threads on this forum on how to waterproof and water cool these ESC's. There are alot of guys, including myself, that have these and think they are great. I haven't heard anything bad with them. There's also this one... http://www.himodel.com/electric/HiMo...200A-OPTO.html
                Government Moto:
                • Flying Scotsman
                  • 5195
                  Nope, you need a high voltage ESC. Neither of those contollers will survive 6S voltage and bustitup's will do the job.
                  Douggie
                  • MonsterMaxx
                    • Jun 2009
                    • 50
                    I guess if I'm really trying to pinch pennies, I ought to be looking at the Seaking 90A also. If I prop this thing the way I ought to it should be fine as well. These can be found in the $40-60 range
                    • MonsterMaxx
                      • Jun 2009
                      • 50
                      Douggie
                      I don't understand why you are saying that, all these ESC are rated to 6s...why would I need a HV esc?
                      • domwilson
                        • 4411
                        Douggie
                        I've read in many posts that the Hydra 120's don't like the 6s configuration and I don't think castle will honor their warranty for it. I have a couple and I am afraid to run them on 6s myself because of all the bad experience's others have had with 6s. Not exactly cheap to experiment with.
                        Government Moto:
                        • Flying Scotsman
                          • 5195
                          Believe me you pushing those controllers for boat useage.
                          Douggie
                          • Rumdog
                            • 6667
                            I ran 6s on a hi-model 82 200 amp esc. I did water cool it myself. It was powering a kb-45 8xl. Ran nice and cool! only ran it a few times though. Not sure how it would be in the long run, but for that price.......
                            • Rumdog
                              • 6667
                              Sorry, meant hi-model 8s
