Need Help with newest 180A SeaKings
  • Mxkid261
    • Jun 2015
    • 734
    I think it's fair to say you've spent enough time on this ESC and it should be replaced by the seller you purchased it from.
    In his first post he stated he has 3 new controllers that are all doing the same thing. I'd be pretty surprised if he has 3 brand new bad speedo's
      • 4338
      You're correct, I missed that. There is something to be said about production batches. So, potentially, all 3 could have the issue.
        The OP states that his old controllers work great, just the three new ones are troublesome. So it seems that either all three new ESCs are defective, or the programming is different/wrong. strange...
        • Mxkid261
          • Jun 2015
          • 734
          Very strange...
          • donhuff
            • Dec 2014
            • 561
            Yes, I don't want to replace it with another one that will do the same thing! And since I have two doing it (haven't tried the third one) I have to suspect that there was something changed in this newest model.
            But I still think that "I" may be doing something wrong as I'm sure I am not the first one to buy this new style, and others are not having this problem.
            I found this morning that I have a different programming card than what is available today. Mine is a hobbywing, but it only supports four function changes. The newer ones have the ability to change 12 different things, with one of them being over heat protection. If I had one of those, I could turn the heat protection off and see if that "fixed" it. But I don't see why they would have lowered the limit on the new ESCs, to the point that the same setup makes them cut off, and the old ones keep running.
            And others have been telling me that running them at less than full throttle will make the ESC run hotter than when at WOT. I don't understand how that can happen but it's what I keep hearing/reading. But I can run these new ESCs at half throttle till the batts are dead, but hit full rabbit, and it'll go about a 1/4 of a lap and shut off.
            AmpDaddy
            don huff
            • donhuff
              • Dec 2014
              • 561
              I just finished reading some other post and they were saying that the V3 model has been around since 2014. So I guess all of the ones that I have are the V3 since they all look alike....except these last three. They have 4 extra caps in the shrink wrap on the power wires. And those four caps are wired together, but separate from the normal two that are usually there. And those four have a red and black wire that runs down into the potting material like the power wires do.
              So I guess this is the newest version of the V3 ?
              AmpDaddy
              don huff
              • Mxkid261
                • Jun 2015
                • 734
                I had one of the first v3 models from 2014 and it didn't have the 4 extra caps just the 2 on the case and the 2 on the diode board on the power wires, I burned that one up. I've heard from many others that these ESC's are designed to be run at full throttle and running it around at half throttle for a full run puts more stress on the contoller than if you were wide open the entire run. I was going to say you should check which program card you have because I'm pretty sure the v2 program card is different than the card for the V3 esc's
                Edit: It looks like the program card is the same, but the listing on OSE says it includes an adapter wire for programming a version 3 seaking ESC
                  • 4338
                  Can this ESC be programmed without a card using a controller?
                  • Mxkid261
                    • Jun 2015
                    • 734
                    Yes absolutely.
                    • donhuff
                      • Dec 2014
                      • 561
                      Yes, but you can only do the basic functions with the tx same as with my simple program card, far as I can tell. Plus I'm 62 years old and can barely hear THUNDER. All that dang beeping and waiting, spinning in a circle, and clicking the heels on you ruby slippers, pizzes me off! I can never get it right, my fault I know, but I still don't like it.
                      I see that they have an LCD programming card and you can do lots more with it, plus I can READ it! Since between me and my son we have 8 of these things (180s and 120s) it should be a worthwhile investment.
                      While looking at several you tube videos. I saw that a couple of the helicopter guys turned off the overheat protection because it "jumps in to early".
                      AmpDaddy
                      don huff
                      • Mxkid261
                        • Jun 2015
                        • 734
                        I don't even have the option to turn off the overheat protection, I'm pretty sure you cannot disable over temp protection on any of the marine controllers. I know there is nothing in my 180a manual about turning off over-temp protection. Which program card are you using exactly? Can you post a link to it or a picture? I'm wondering if the card your using is not meant for the v3 seaking ESC. Even though it might make a tone and show you changed a parameter, it may not actually be changing. Just a thought
                        • donhuff
                          • Dec 2014
                          • 561
                          I don't have that option on my old card either. And your right about it not saying anything about it in the manual. But on the hobbywing direct north america web site, you can see it, and several youtube videos show it.
                          I said that on the new version, and the LCD program card, you DO have that option.
                          Hummm, well after looking closer. It shows that on the boat escs, you still only have control over the same four settings. Well dern!
                          AmpDaddy
                          don huff
                          • Mxkid261
                            • Jun 2015
                            • 734
                            Ya the air ESC's might have more parameter's to change than the boat ESC's. Like stated, there are only 4 parameters you can change on the boat ESC's. I'm willing to bet your program card is not actually changing the parameters of the controller. Is this the card your using? http://www.offshoreelectrics.com/pro...-seaking-pcard
                            • donhuff
                              • Dec 2014
                              • 561
                              Mine looks like that other than it does not have but the four parameters on the front.
                              it changes the battery voltage and timing Im sure.
                              AmpDaddy
                              don huff
                              • Mxkid261
                                • Jun 2015
                                • 734
                                Hmm...shouldn't be the card then. I'm just about at a loss then Lol. You may want to try contacting Hobbywing North America. They have warehouse's in Los Angeles and Reno.
