Can the sk180 handle a leopard 4092 1480kv on 6s? I will be putting that motor motor in a jae45 Outrigger and was wondering if i would need a esc that could handle more amps or do you guys think the sk180 can do the job. The prop i am using is a1450 thanks
Tags: None
It might, at least for a while. Several club members used that controller with Neu 1527/1Y motors on 6S in sport hydros and as long as they did not overprop the controller worked. Neither lasted more than six months IIRC.
I would think so. I have been running that motor on 6S with a Swordfish 220. So far the largest prop has been M545, but the logged amps are under 100, except for some peaks around 110.
Was that in a 36" rigger? That's a tiny prop for that motor, the 1450 loads the motor a lot more. The JAE is a pretty big boat too. It may work, but the OP should be careful.I would think so. I have been running that motor on 6S with a Swordfish 220. So far the largest prop has been M545, but the logged amps are under 100, except for some peaks around 110.
Originally posted by Fluid View PostWas that in a 36" rigger? That's a tiny prop for that motor, the 1450 loads the motor a lot more. The JAE is a pretty big boat too. It may work, but the OP should be careful.
It's my starter prop on a 36" Ariane 2 mono. I have an M645 to try next. Expect to grow into an M547 or M450. That's if the hull remains stable in oval racing.
I run the exact motor and esc combo in a Pursuit mono with a 1914 abc. The SK seems to take 3 minute runs just fine. Right at 60-62 mph. I have no clue about how the OP's boat compares to a pursuit however. Just for good measure I removed the two little caps on the power wires and replaced them with 8 larger ones. Great esc I think, good luck.
My twin rigger is equipped with Leo's 4092 2080 on 6S with a pair of T180 (modified with cap banks and improved cooling)........3 min runtime with no issues after one year!here a link where you can see it:http://grsboats.com.br/novosite/?por...twin-fe-rigger
GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
Yep..Tamelesstgr ...Fe boats produce amazing ones .GO FAST AND TURN RIGHT !
www.grsboats.com.br
Check out Gill's thread on modifying the heat sink. There are a few mod threads that will help out if you search for them.Originally posted by grsboats View PostMy twin rigger is equipped with Leo's 4092 2080 on 6S with a pair of T180 (modified with cap banks and improved cooling)........3 min runtime with no issues after one year!here a link where you can see it:http://grsboats.com.br/novosite/?por...twin-fe-rigger
Gill
