Hobbywing / Skywing (rebadged Ez-Run) esc's, any info ???
  • gsbuickman
    • Jul 2011
    • 1500
    Originally posted by Alexgar View Post
    A couple more things are you mat need to check that the motor outputs solder joints dont touch the heatsink so when heated they arc out burning up the esc. Also the fets in the older ones didn't all touch the fets so I personally sanded them flat and seated the water cooler others used thermal epoxy. Just a little heads up
    Thanks for the heads up Alex
    I am versed in sanding FETs & thermal paste. I also build pc's and I find the water cooling blocks for PC's work great on ESC:s ...
    http://www.ebay.com/itm/130972362635...84.m1423.l2649
    http://www.ebay.com/itm/321214878651...84.m1423.l2649
