Seaking 120 help
  • Savage Skidoo
    • May 2011
    • 312
    Seaking 120 help
    I got my order from OSE thanks btw very quickly . In it was 2 -120 amp Seaking's esc , i got it all wired up with a c/c bec and a leopard 3674 - 1700kv motor on 2x3's 5000 for a bench test , all went well .I unplugged everything . i went for dinner came back to test again , motor dose not turn , servo works , i changed motors same thing , on that same set up i took a T-180 and all is good , is this new esc junk , i rebound all , reset all , esc seems to get warm from me pulling the trigger & the beep beep sounds ......any help would be great . Mike
    www.facebook.com/Boaters and Crawlers Durham
    Durham Off Road Rc Club - www.dorc.ca founding member
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1518
    Your Seaking also has BEC built in. If you hooked it up with an external BEC, the two are not playing well together. Either remove the red wire from the ESC or discontinue using the external BEC. I hope you didn't fry the internal BEC in the Seaking with both hooked up, but it's possible.
    • Savage Skidoo
      • May 2011
      • 312
      I know this Ray , i also picked up a wire extension too pull the red on it so i still can use my program box when in need ....i have stripped it and wired up the 2nd one i purchased , it works fine
      • Savage Skidoo
        • May 2011
        • 312
        sent it back .....i did
        • Savage Skidoo
          • May 2011
          • 312
          Well just too let yous know , i hooked up the 2nd ESC i got from OSE , bench tested it and water tested it . I took it to the lake for a test . With in 1 min run time the boat seemed rather slow then a strange noise came from the boat the 2nd esc has stopped working , shipped it all back too OSE , now we wait $415 order up in smoke , I believe that this 3674 1700 kv motor took out both esc's . This motor was brand new from ose too . Or is it possible 2 esc are NFG .
            • 4297
            Hey what boat where setting up with that setup and on what prop ?
            You say a strange noise, Was is the caps popping ?
            • Savage Skidoo
              • May 2011
              • 312
              Len its a H&M Drifter 'S' 26" , wat was in it was 2x3s 5000 p220
              • Savage Skidoo
                • May 2011
                • 312
                this motor was hardwired add on's for flex , I see my buddys motor same , but wires are different .
                • bigwaveohs
                  • 535
                  I run that 3674 on a T-180 with 5S...a 120 might not be enough...
                  I let the dogs out...
                    • 4297
                    Why do you have four plugs going to the rx ?
                    Also what connectors are on the motor with the very small jacket on it ?
                      • 4297
                      What motor is that one in it ?
                      Originally posted by Savage Skidoo View Post
                      [ATTACH=CONFIG]108486[/ATTACH]
                      • Savage Skidoo
                        • May 2011
                        • 312
                        [ATTACH=CONFIG]108490[/ATTACH]
                        Just a mock-up motor till the order came .
                        • properchopper
                          rcgoatbuild@snotmail.com
                          • 6958
                          Are you running your packs in parallel or series? I may have missed that but ?
                          • TheShaughnessy
                            • 1419
                            He is running 5s. 2sx3s 5000's according to post 7.
                            Something is up here.. Operator error ? Thought savage has been around the block a couple times.
                            • properchopper
                              • 6958
                              Post #7 says 2 X 3S - at 3.7V nominal that's 37,740rpm. With a P220 that may draw more current than a T-120 is comfortable with.
