HobbyWing Seaking 60 A acting strange?
  • paultbg
    • Mar 2012
    • 103
    Hello
    I have the above Seaking 60A esc in a mini boat.From few days now, when connected to the batteries, is not detecting the right number of cells (3s) only 1 and is making only one beep.
    Otherwise it seems to work ok. I have tried on auto setting and also setting manually the number of cells, still the same thing.
    Any ideas? Maybe you have experienced this before? Please advise.
    Regards
  • Heaving Earth
    • 1877
    Is it calibrated to the radio correctly?
    • paultbg
      • Mar 2012
      • 103
      Hello,
      Yep,calibrated several times...still the same problem.Any other ideas?
      Regards
      • bikergreen
        • 422
        do you have a program box? It may have ended up getting changed from auto lipo detect some how..
        • paultbg
          • Mar 2012
          • 103
          No, setting are changed every time with only the radio...i do not have a box
          Tx
          • martin
            • 2869
            Get you self a prog box anyway, best $10 you could spend.
            • MAMBA2200
              I need a scooby snack
              • 1196
              you must have the box its the only way to really know and there very cheap
              • paultbg
                • Mar 2012
                • 103
                Just a quick update to let you know that I found out what was the problem with my ESC.
                When the LVC is disabled, the ESC is not counting the cells anymore.
                Once I have set the LVC back to 2.8V the counting started again...
                So I am guessing that the only purpose of the cells count is to know the voltage when to cut off.
                Regards
