120amp seaking with a 4074
  • devo
    • Aug 2012
    • 156
    Is a 120amp esc enough esc for a 25 inch delta force v hull running a 4074 2200kv on 4s? I will be running somewhere between a 440-444 prop for this
  • Basstronics
    • 2384
    Ya that motors way to big for the hull.
    120A wont work, 180A.
    • devo
      • Aug 2012
      • 156
      Thanks for the opinion but ive been running this motor in this hull with a swordfish 200 for a while now with no issues, problem was I put the swordfish in a new build and it blew up, so im wondering if the 120 will work
        Yes,
        I am running that motor and a t120a esc on 4s and a x646/3 prop in a 36"PB Shockwave,
        Modded to FE.
        I just had to add three 1000ur caps to the esc to keep the temps down on them,
        Runs very nice at 42 mph and about 6 minutes of run time on 2x4s 30c 3600mah packs.
        • devo
          • Aug 2012
          • 156
          Lenny thanks for the input, I have a stiletto with a 120 on5s but it's on a stock proboat 1800kv motor and with a 442 prop consistently get 56 + mph, it does have a lawless 3.5 though, which makes quite a difference compared to the stock outdrive.
            Have any videos of it running ?
            • Rumdog
              • 6667
              That esc will melt down. Your motor can and will pull well over the rated 120 amps. Go with the Seaking/T-180.
              • devo
                • Aug 2012
                • 156
                What do you think about a 3674 1900kv on a t120 in the 25? I would probably run 5s on this set up
                • devo
                  • Aug 2012
                  • 156
                  I have a friend who takes pics and vids of our boat club & will see what I can come up with
                    What setup are you talking about that will melt down ?
                    • stadiumyamaha
                      • 1371
                      As long as you stick to 4s and don't go big on the prop it will be fine.
                      • dana
                        • Mar 2010
                        • 3660
                        120 could be ok. I run same setup but with 180 which is prolly overkill
                        • dana
                          • Mar 2010
                          • 3660
                          I'm planning on running it on 5 s
                          • 785boats
                            Wet Track Racing
                            • 3423
                            Devo.
                            That T120 will easily spin that motor in the 25" delta with those props. I've run that combination in hulls up to 32"
                            Two things though. Add a couple of capacitors for insursance. And get yourself an X440/3 prop rather than going up to a 44mm size. The boat handles much better in my opinion with three blade props. Less torque roll than with bigger diameter props. More stable in the corners too.
                            • devo
                              • Aug 2012
                              • 156
                              Okay, here is an update on what ive decided to do. I sold the 4074 2200kv motor and plan on going to a 3674 1700kv leopard motor, a seaking 120 esc, and run it on 4 & 5s, what do you guys think about that setup?
