Seaking ESC testing, capacitors? Warranty?
  • kevinpratt823
    • Aug 2012
    • 1462
    I have a Seaking 180 that doesn't respond to throttle input. The steering works, and it draws a small arc when plugging it in. Could it be an easy fix, possibly capacitors? How can I test this to find out?
    I have sent an email to Hobbywing for warranty a few days ago, haven't heard back. I did a search for Seaking warranty on here bu found nothing, is there a quicker route to get replacement if I can't get it fixed?
    Thanks for any input.
    My private off road rc track
  • drwayne
    • 3012
    does it 'play' music through the motor on 'arc' up ?
    • kevinpratt823
      • Aug 2012
      • 1462
      I meant to mention that, thanks. No, it does not make any sound(through the motor)
      • drwayne
        • 3012
        Hi
        1) is it labeled Seaking 180 or Turnigy 180 ?
        The Seaking had an on/of switch I seem to recall.
        2) if the signal(white) wire from Rx to esc is damaged/broken,, the esc wont 'startup'
        W
        • kevinpratt823
          • Aug 2012
          • 1462
          Hi
          W
          It is a Seaking, I've had a couple of them, no switches, pretty sure the wires are all there, and even if it's not plugged in to a reciever, I'm pretty sure it would chime single tones until it gets a signal..........
          • devo
            • Aug 2012
            • 156
            I've got one seaking 180 doing the exact same thing, mine is almost new and the problems started after I reprogrammed it, I actually bought mine from offshore electrics and was going to see if they would help me out.
            • kevinpratt823
              • Aug 2012
              • 1462
              I got mine from Steven about a month ago also, but if I can take care of it myself directly I'd rather not bother him with these issues.
              • devo
                • Aug 2012
                • 156
                Thats about the same time I bought mine from him, im wondering if there is a bad batch of these escs going around, please let me know if you figure something out
                • KartRacer
                  • Aug 2012
                  • 363
                  Mine has done the same thing, I thought it was the Traxxas radio and receiver so I ordered a new Futaba radio and receiver, Took the receiver out of my truck and It works fine now and no there is no music. I think it is the Futaba Connector not making proper contact. Wiggled the connector and it works fine. Unit is also from Steven. going to hook the new radio and receiver tomorrow.
                  KartRacer ~ Dennis B
                  Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
                  • kevinpratt823
                    • Aug 2012
                    • 1462
                    I will double check my other Seaking 180 tomorrow, but I'm almost positive that if you plug just a battery into the esc, without plugging the esc into a RX, you still get some tones, just a single beep every 5 seconds or so I think.........So it is likely not your RX.
                    • KartRacer
                      • Aug 2012
                      • 363
                      Ok so you all had me wondering. So I went out and set up the new radio. Seems logic is a little strange but all is good now working properly.
