Seaking 180 problem
  • stadiumyamaha
    • 1371
    • stadiumyamaha
      • 1371
      Wake. I would like to see the recal on the seaking.
        • 6057
        If you mean how to do it, here it is:
        Handgun style TX:
        Move the throttle stick to the maximum position, full throttle.
        Connect Batteries to be used.
        after 2 seconds........beep, beep. Full throttle confirmed
        Release stick to neutral........beep, beep. Neutral confirmed.
        Reverse doesnt need to be "ranged", but its there if you choose to activate it, its kinda handy really............you just dont push to reverse for any reason when moving and be mindful of it.
        The biggest thing here is to make sure the throttle trim is at neutral, not a hair forward or it'll rev all the way up and blow the motor(how do I know???)...........if its too far back then full range wont be known............etc.
          • 9481
          Handgun style TX:
          Ouch
          • dana
            • Mar 2010
            • 3660
            Handgun style TX:
            My throttle is set to reverse with trim all the way up.
            • Bigbore
              • 179
              Are you using auto cell count? On my Seaking 180A I solved the lvc issue by programming the number of cells I'm going to use and I have the lvc at 3.2V.
              • stadiumyamaha
                • 1371
                I always set the cell count.
                  • 6057
                  Yeah throttle set to reverse, forgot that part................
