Seaking & tacon 4074 - 2150 KV motor timing question
  • ratchet
    • May 2012
    • 23
    First of all, this forum has helped me a lot, as this is my first FE boat. So thanks to all for sharing your knowledge.
    I put together a R2 Hobbies godspeed cat, with a seaking 180 ESC & a Tacon (same as leopard 4074) - 2150 KV motor. It is powerd by 2 7.4 v batteries in series (Turnigy 5000s 45-90 Cs)
    Before I go out I was curious as to what a good starting point for the timing would be. I'm starting out with the Graupner 42 dia x 59 pitch (similar to the X442) and I have a 45 x 63P (similar to the M445).
    I put a lot of work into stuffing all of this in the hull & I do not want it to go poof as soon as I pull the trigger
    Which prop would be the bests to start with & what timing should I start at (I read a lot & think maybe 15 is a bit much ?)
    Thanks,
    Mike
  • stadiumyamaha
    • 1371
    Start with low timing and the smaller prop. Check temps and move up from there.
    • ratchet
      • May 2012
      • 23
      looks like my options are 0, 3.75, 7.5, 11.25 15 (default setting), and 18.75, 22.5 & 26.25
      Thanks Stadi........
      Would starting at 7.5 be safe, or should I go lower ?
      How do I know if I'll need more timing ?
      • stadiumyamaha
        • 1371
        7.5 to 11.25 should be fine. I've never noticed a huge difference after raising the time, may be a mph or two but isn't worth the damage it may cause IMO.
