OK so why does the 130a version cost more than the 180a?
SeaKing 130 vs. 180
I have only used the 180 up to 4s, yes, I use the BEC feature on that unit. From what I have read, you can get by with 5s, going to the max which is 6s on that unit one needs to disable the BEC and run separate receiver pack. Anyway, this is what people do to avoid failure even though the spec sheet says BEC is rated up to 6s.
From what I read about the 130, there is no built-in BEC feature since it will be used with as a HV ESC by people who use it.Too many boats, not enough time...
Exactly what i wanted to hear. Thanks for helping me out!Originally posted by tlandauer View PostI have only used the 180 up to 4s, yes, I use the BEC feature on that unit. From what I have read, you can get by with 5s, going to the max which is 6s on that unit one needs to disable the BEC and run separate receiver pack. Anyway, this is what people do to avoid failure even though the spec sheet says BEC is rated up to 6s.
