Seaking 180 amp esc question
  • darrin4800
    • Aug 2011
    • 1115
    I have a new 180 amp seaking esc and when i plug in a battery a red light blinks and it doesent do anything.
    Help. Thanks.
  • rc2266
    • 317
    Got programer?
    I'm married with children, you can't scare me!
    • darrin4800
      • Aug 2011
      • 1115
      Yes I do.
      • de-pro
        • Aug 2011
        • 186
        Is it connected to a receiver. Did you bind the receiver to your radio (spektrum only)
        • darrin4800
          • Aug 2011
          • 1115
          I just have the motor pluged in and a battery.
          • de-pro
            • Aug 2011
            • 186
            If you have the program card then its all you need, otherwise you will obviously need a radio to do anything else with it
            • darrin4800
              • Aug 2011
              • 1115
              I cant get the programing card to work.
              • battlefury
                • 301
                Just removing the red( postive wire) from the RX plug(ESC) and supply an external power source to ur reciever.
                Most probaly, ur internal BEC is disfunctional. And set your Lipo cut off to non but monitor your run time
                http://www.youtube.com/user/f4agusta09?feature=mhee
                • runzwithsizorz
                  • Jan 2009
                  • 901
                  There should be no need for him to remove the red wire, YET. WE, do not know his boats, and radio specs, how much experience he has, if he knows how to *properly* remove the red wire, if he is inserting the plugs correctly, if he even has an RX battery,
                  if he has the instructions. Always advise someone as if they were a complete noob, unless you know otherwise.
                  Take your time OP answers will be forthcoming.
                  • de-pro
                    • Aug 2011
                    • 186
                    connect the wire from your esc to the top right connector on the programmer with your black negative wire being the first one on the left
                    Plug in the power to the esc and wait for a few seconds. The programmer should light up and then follow the instructions on your programmer
                    • pyroM!KE
                      • Jan 2011
                      • 379
                      Help. Thanks.
                      If your running a futaba radio or similar, reverse the throttle channel..Try it..
                      • battlefury
                        • 301
                        Sure thing, Darrin when you have those 'gray' areas as he pointed out competent enough you can then perform whatever remedy that discussed in here. I agree with runzwithsizorz he is just being concerned. the advice i gave is because the similar issue has occur to me twice before on turnigy 180 and SK180 . it did work at least to me.
                        • darrin4800
                          • Aug 2011
                          • 1115
                          Thanks to all.
                          • darrin4800
                            • Aug 2011
                            • 1115
                            Thanks battlefury you are the winner. You were right the bec has A problem, I put in an external one and it works fine.
                            Thanks again for all your help Darrin.
                            • battlefury
                              • 301
                              Good Job!
