seaking 180
  • Gary
    • Jan 2009
    • 1104
    seaking 180
    Just installed a 180amp Seaking and my question is how do you not have to go into throyyle setup everytime you power everything up? Tried shutting off the reciever first, the transmitter first , ran a seperate battery pack to the reciever and shut down a few other different combinations..... still have to go to throttle mode setup each time I repower. What did i miss? Thanks
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
  • dana
    • Mar 2010
    • 3660
    program card?
    • Alexgar
      • Aug 2009
      • 3701
      my turnigy doesnt do that maybe somethings wrong with it
      • carlcisneros
        • Jan 2010
        • 1237
        first off did you calibrate the Throttle?
        THEN, did you actually program it?
        Calibrate first, programming second.
        Very important.
        if you run a seperate battery for the receiver, make sure and remove the RED WIRE from the plug going to the receiver from the ESC.
        • Boaterguy
          • 1779
          if your throttle channel is reversed, it will recognise it at full throttle on power on which brings it into program mode.
          • Gary
            • Jan 2009
            • 1104
            All set. I did the program again but also my throttle trim was also to high. They where set for my Castle controllers. Thanks guys.
            Chris Craft 16 mph
