can i extend the leads or do i have to unsolder at the base and use a new longer wire?
Seaking 180 extending leads
you want your wires to be as short as possible. i would solder bullets on and make some extentions. desoldering for the board is risky at best, and just soldering wires together isn't exactly great. there are a lot of amps going thru your wires, so the more connections and wiring, the worse off you are. always keep all your wires the same length too
like Dana said just make some extenions with the same gauge wires , i have done it with some of my boats were i cant get the ESC close to the batteriesUL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
I do the extensions myself. I use 5.5 or 6mm gold bullet connectors. You will have a little added resistance but if you go with 10 gauge wire you won't notice much difference. Keep them as short as you can.
DO NOT CHANGE THE LENGTH OF THE MOTOR LEADS!Mini Cat Racing USA
www.minicatracingusa.com
I have a difference of opinion on this. If you are going to make extensions, consider doing it with the next size larger wire, and use larger connectors on the motor lead ends (keeping the original ones on the esc end). Extensions kinda suck altogether, but are sometimes necessary as we know. Staying with the same guage wire & connectors will increase resistance and cause heat and power loss. By using larger wire & connectors you will reduce/eliminate these losses. Keep it large and short is the gist of it.Originally posted by scoota View Postlike Dana said just make some extenions with the same gauge wires , i have done it with some of my boats were i cant get the ESC close to the batteriesLegend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
even if you use 8 gauge as extensions it is choked going into the 10 gauge wires, so i disagree , its a bit like flow of water down a hose with a kink in it , yes i agree about the bigger bullets , cause the bullets are the weak link !!!Originally posted by sundog View PostI have a difference of opinion on this. If you are going to make extensions, consider doing it with the next size larger wire, and use larger connectors on the motor lead ends (keeping the original ones on the esc end). Extensions kinda suck altogether, but are sometimes necessary as we know. Staying with the same guage wire & connectors will increase resistance and cause heat and power loss. By using larger wire & connectors you will reduce/eliminate these losses. Keep it large and short is the gist of it.Last edited by scoota; 05-06-2011, 01:14 AM.UL1- 1515 castle/neu / 240 swordfish
Yeah, I know it doesn't sound right, but is. When I used to install solar electric systems (when they were 12v - that's showing some age there!) the copper line might be 4/0 - about the size of your little finger. And it was customary to pigtail a smaller gauge to it to fit it into the connector in the box. The wire was way large to keep resistance down (low volts=high amps) until it got to the box, then you'd treat like the smaller gauge again.Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
