Seaking 180 Possibly Blown?
  • 6sHyper
    <<<Surfs up!
    • Jan 2011
    • 597
    i would highly recommend switching out those ec5 connectors for some bullets, 5.5-8mm
    • Shaun78
      • Feb 2011
      • 416
      i have alot of EC5's but if i have anymore issues then maybe i will switch...
      Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
      (63.7 MPH) Traxxas Spartan (same setup)
      • Shaun78
        • Feb 2011
        • 416
        Like u said Dan, NO way i got a lemon from you. ITS AWESOME but u know S%$& Happens. I might order a mnew one anyways (for a spare)
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          Guys disconnect the BEC , i have 3 of these ESCs & i never run the bec on 4s or 6s, i have them in boats drawing 200+ AMPs & never had an issue . Well apart from the LVC which we all know about ...
          UL1- 1515 castle/neu / 240 swordfish
          SV27- with UL1 running gear
          33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
          • Bigbore
            • 168
            Could you explain something about the LVC?
            I've been using the Seaking 180A ESC on 5S with external BEC from a couple of month and I have the feeling that my ESC cut the power at 50% (LVC) above of 3.2V as programmed.
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 409
              At 3.2 volts it was cutting in to early , i have found setting it at 2.8 volts on my high draw set ups my batteries were coming back with a 1000 mah left in them , i have read a lot of people have been turning off the LVC to over come this issue , or you can run a external LVC .
