Seaking 180 Possibly Blown?
  • Shaun78
    • Feb 2011
    • 416
    I ran 6S the other day and it was fine. Temps at capacitors were 122 and ESC was 105. I went to run today and when i plugged in the batteries nothing, I could here a little sizzle and kept trying and sometimes it beeped like normal but very faint. Could it be a loose connection maybe but if i keep the batteries plugged in a def here a little sizzle and a small odor then i unplug. I took it apart and nothing seems burnt. How can I tell? Did i maybe just blow one of the capacitors?
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • Alexgar
    • Aug 2009
    • 3522
    Check the bec I burnt mine yesterday on 4s just kept beeping once I put a rx pack it worked so I put a external bec
    • Shaun78
      • Feb 2011
      • 416
      I am not using the BEC. I am running a seperate battery pack
      • m4a1usr
        Fast Electric Addict
        • 2032
        Did you do a visual inspection? Bulging end cap or body distortion? Next take a look at the leads. Caps can go bad without any obvious external visual cues. For the home/ garage hobbyist the only way I know to verify whether a cap is good or bad, and this is only cursory, is to remove it from the circuit and measure the IR. Using the 20meg setting you will see a resistance value that will continue to increase as the cap trys to charge up. Next charge the cap using a 6s pack. Again take a resistance reading on 20meg. Your DMM should read 0 ohms. If it reads some resistance its most likely bad.
        Its the "sizzle" comment that tells me you have some other issue. I never recommend running an ESC to the full rated manufacturers description for voltage. Especially the cheaper chi speedos. At least every couple weeks this same story seems to appear in threads. Then you hear about the guy running one on 7S. All that does is confuse the rules to learn to live within.
        You most likely smoked the speedo because of pushing it. Whether related to voltage or amperage. Doesnt matter which did the job. So you have to ask yourself. Do I want to throw away another $100? Sooner or later it will dawn on you. I have a couple T180's that run moderate amp loads, around 100-150 amps depending on water conditions. But both only on 4S. Just my 2 cents for what its worth.
        John
        Change is the one Constant
        • Shaun78
          • Feb 2011
          • 416
          I hear ya but my next choice is what? Castle ice 240?
          • m4a1usr
            • 2032
            The 8S 200 amp CC Ice may not be a bad choice. Its only a little over 200 bux. Seems to be a good drop in choice. Then there is the Etti or the SwordFish. I have run my Etti 150 on 6S and it did not smoke. But only once and not pulling more than 100 amps. Which I have also done with a CC240LV. But same circumstances. Low amperage.
            With the recent threads about the Hydra HV and the Ice HV I have no solid opinion. Its too early to tell. One week I hear of a racer running one for awhile, next week I hear another where it blows up on plug in. That disturbs me. I wont be buying any for some time. Maybe Ben (fightercat) has some good news for his 200 amp speedo. I think it is rated to 8S? But he would have to give you the skinny. None of the Suppo/Himodel series I have seen looked like they would last using 6S. Good luck.
            John
            • 6sHyper
              <<<Surfs up!
              • Jan 2011
              • 597
              The T180 can handle 6s no problem, all day long! Shaun what motor are you running and what prop and boat?? IMO the T180 is the best bang for your buck speedo on the market by far! its underrated if anything. Ive pushed one to the limits consistantly without it going, i mean i guess some people have better luck than others but i wouldn't be blaming the fact you ran it on 6s for the failure, its more than capable of handling the volts, obviously the amps could be an issue but still they handle a darn godo amount of amps!!
              • Shaun78
                • Feb 2011
                • 416
                Leopard 4082 1500KV on 6S. It ran fine last time and i put her away and today its crackling, i dont get it....
                • Shaun78
                  • Feb 2011
                  • 416
                  I think it was version 1..doenst say version 2 like my other one does. Hmmm,do I chance it and buy a new version 2
                  • 6sHyper
                    <<<Surfs up!
                    • Jan 2011
                    • 597
                    what prop and hull?? you have a genesis wasn't it?
                    • Shaun78
                      • Feb 2011
                      • 416
                      genesis with 642 prop...like I said was fine last I put her away. Plug in sometimes I hear faint bepps but also a little sizzle and faint smell of something not good.
                      • Shaun78
                        • Feb 2011
                        • 416
                        but the spartan was running fast. Gps was 56.6 then I put a 645 prop on and it had to be 60 or better,no gps that run..
                        • Shaun78
                          • Feb 2011
                          • 416
                          Well I lucked out......esc is fine....it was a bad solder connection on my ec5 connectors...soldered on a new ec5 and it's good as new........saaweeeeettttt
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3278
                            Sweet. Wish mine was an easy fix. I ran my 180 a few times on 6s, then sold the hull. Went to use the 180 in another hull a couple months later, and nothing. Dead as dirt. Found the BEC wires barely soldered on the board. I fixed that and nothing. I ran a RX pack and still nothing. Sucks. I ran the esc maybe 6 times total before it did this crap.
                            • dano1
                              • Dec 2010
                              • 403
                              Good to hear shaun, didnt think i sold ya a lemon, keep in mind that boat is far from stock and they put a tremendous amount of power thru the electrical systems, with power comes grief...it goes with anything. I ran my kos today after a piano wire set up and alot of other goodies, made 3 runs at good speeds and burnt up a motor, no.....it wasnt over powered, its electrical and electric does some strange things sometimes, now im tearing it down and putting in (top gun) secret motors, shooting for 65 with 7 minutes run times. Putting in big blocks, lol
