Programming Seaking ESC?
  • Shaun78
    • Feb 2011
    • 419
    I am running 6S. Should i use auto detect or set #3 says 3cells (6 cells) Does that mean 3 or 6 cells?
    i will probably do 3.4 low voltage and 15degree timing and forward only just in case i need it....
    BEC disconnected u still need to plug in power pack and lipos to ESC?
    Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
    (63.7 MPH) Traxxas Spartan (same setup)
  • Diesel6401
    Memento Vivere
    • 4391
    Don't use auto. Manully program. The first number is for LV esc's i.e the 120/180 the (x) number is for the HV esc's. i.e 80amp HV. What exact seaking do you have?
    So setting 3 is:
    3s on the 120 & 180
    6s on the 80HV
    * Timing depends on which motor you are running. 15 is great on a y wind, but may heat things up on a d wind. Which motor you running?
    * Yes if the bec is dis-abled you need to still plug in your lipos and you will need a rx pack.
    - Diesel's Youtube
    - Diesel's Fleet
    • Shaun78
      • Feb 2011
      • 419
      I have the Seaking 180 with Leopard 4082 1500Kv. Running 6S lipos.
      Setting 1 is 2 forward and reverse(i will only use if needed)
      Setting 2 is #3 for 6S
      Setting 3 is #5 3.4V/cell or maybe #4 3.2V cell
      Setting 4 is # 5 15 degree timing
      • Diesel6401
        Memento Vivere
        • 4391
        Dump the reverse.
        # 3 on a 180 is not 6s it's 3s. You need to change to setting # 6 on the 180 for 6s. The 180 is not a HV esc, there for the number in () is not applicapable to that esc.
        I run 3.2v per myself.
        15* is good for that motor, its a y wind
        - Diesel's Youtube
        - Diesel's Fleet
        • Shaun78
          • Feb 2011
          • 419
          Ok, #6 says 6cell (12 cell). That's what setting I want to run 6s?
          • Diesel6401
            Memento Vivere
            • 4391
            Yup, ignore the the number in the () is does not pretain to you!
            - Diesel's Youtube
            - Diesel's Fleet
            • Shaun78
              • Feb 2011
              • 419
              Got it,thanks
