Hobbywing ESC Programming card faceplate
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    NOTE* If you use a hobbywing programming card, check to make sure it has the right faceplate. The cards are interchangeable, but the options are different.
    There are three different faces for the programming cards.
    Platnum AirCraft/Heli:
    EZ Run Car:
    Boat ESC:
    After watching an outrunner glow red, I realized that my programming card had the WRONG faceplate and I was setting the timing at 0 instead of the punch control at 1. Nowhere in the instructions had this explanation and the card came with a boat ESC. Some Hobbywing dealers are shipping the wrong faceplates on the "combo deals".
    (OSE has the correct faceplate)
    So if you use a programming card from an airplane, heli or car esc, check the faceplate for the correct values/info.
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    OR you can follow the flow chart on the esc manual. I just carry it in my tool box. I use the same box for my trucks too.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Yep. =)
      • D_hob
        • Jul 2014
        • 3
        Seaking 130A - HV ESC programming manual is here.
        1. program with your transmitter
        2. program with a hobbywing program card. (see under troubleshoot section)
        HOBBYWING Seaking v3 User Manual, Troubleshooting, How-to set up, available through FalconSEKIDO.com, r/c rc marine boat ESC
        hope this helps.
