Swordfish 220 x won't connect to pc
  • Raydee
    • 1619
    It connected no problem and was programmed. I then checked out the data logging and it worked fine but then after the next run it refuses to connect again. I tried running as administrator and also deleting and reinstalling the software (6.0 or 6.1) without any luck. Anyone else have this happen to them?
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
  • trigger
    • Sep 2013
    • 853
    I've had the same, turned out to be a wire in the USB connector that was not connected to the board. Only found it because the plastic cover was so loose.
    • Raydee
      • 1619
      Well I will have to open it up and take a look, hopefully its that easy considering that is the only way to program the ESC.
      Team Liquid Dash
      • Raydee
        • 1619
        Didn't have to open it after all, purchased a new cable and it works like a charm again.
        Team Liquid Dash
        • trigger
          • Sep 2013
          • 853
          Well that's good news
