Swordfish 300
This topic is closed.
  • oscarel
    • Dec 2009
    • 2373
    Swordfish 300
    Wonder how this got by quality control. This is a friends and it's brand new, he luckily tested the cooling before using it. IF he had used it and it burned up, how would you have been able to determine the fault? I had one of these enclosed ones that burned up on me and it was determined user error because there was a mark on the outside that "could've" grounded.. There's no way this should've been closed up and sold.
    No doubt, I know there has been the odd 'Lite' version with the same issue. WOW!
    • jim82
      • Jan 2013
      • 1358
      That is insane that is why I am not a big fan of them.
        Wonder how this got by quality control....
        What quality control?
        I'm glad you posted this Oscar, I was about to when I saw your thread. The sad truth is that reliable, high voltage ESCs are rare as hen's teeth. I have a couple old Schulze 40-160s in my 10S boats, don't know what I'd use if I didn't have them...
        • oscarel
          • Dec 2009
          • 2373
          What chaps me is I had one that burned up and it was deemed my fault. Even though I sent in files from it from the previous runs to show I didn't do anything wrong. I've burned up my share of esc's which I"ll admit to when it's my fault. But this one I didn't believe was. This was there reasoning:
          Hello Oscar,
          The attached are pictures of your 300A ESC when removed the sealant glue. Many MOSFETs were split from the circuit board, which is rare situation but only happen when there is over 200 centigrade. We think there happened short circuit because the battery cables exposure touched the case and caused very high current shortly.
          Couldn't the short circuit happen AFTER the esc overheated and the wires started coming off??? Once the one I have quits, I'm done with them.
          • Fast Learner
            • Dec 2014
            • 2
            I have had 100% of my smaller Swordfish ESC's blow in the first run of the boat.
            • Peter A
              • 1624
              I have a 220 pro plus that has bulged all it's fets and is dodo after less than 12 runs. I put a T-180 v2 in the boat and it doesn't miss a beat, even though it has had 3-4 years use. I don't think much of the SF esc's in comparison. I guess there are good ones though.
              • 427srule
                Racer
                • 188
                Here is a 300 amp Lite Version
                I wanted to change the tubing so I cut the shrink off and look what I found
                • jim82
                  • Jan 2013
                  • 1358
                  They are killing them selves by doing stupid stuff...smh
                  • grsboats
                    • 1011
                    Yesterday we had another burnt with this esc due to a water leaking....I agree that they do stupid things like this junky water line so I'm happy to had figured out this problem when I received my unit....Here a quick mode that will save some bucks..at least mine is working good after one year now.
                    GO FAST AND TURN RIGHT !
                    www.grsboats.com.br
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      I almost bought one of these as a back up ESC for when I want to beef up my zOnda.
                      • grsboats
                        • 1011
                        Keagan I would say that this is a good esc once you make this mod.
                        www.grsboats.com.br
                        • 427srule
                          Racer
                          • 188
                          I really wish there was a cooling plate on the top and bottom and not just tubing running down each side.
                          I've added a cooling block which has helped tremendously but why do I have to modify an almost $300 controller?
                          When it's 100 degree's these controllers get hot and it's only a matter of time before they fail.
                          On a another note, anybody have luck getting an RMA number from the Sales2@hifei.com email ?
                          I sent an email May 1st and August 28th and haven't received a response.
                          Thanks,
                          Mike
                            I cut the shrinknoff of every one. I've found issues on half of them I've checked. Here's a pic of one I happened to take. Another didn't have a zip tie on one side of the cooling tube. What? If that popped off that could sink the boat.
                              Hello Oscar,
                              What other choice do you have for a high amp esc? Wonder if we could get Steven involved and he could have someone make a quality esc. Seaking we know does make a quality unit but they don't offer anything high amp wise. I know that they "will" make specialized escs for you if you have enough $$$, case in point, proboat dynamite escs are made by them and they have thermal cutting which is a nice feature. I think a 250-280 or even 300 amp Seaking would be the shiznit. If I had the cheese I'd persuade them to make one. I really think there is a market for it at $300 because the sf300 sells like hot cakes and look at the lack of quality control that they have. I haven't seen anything negative with Seaking escs yet.
