swordfish 240 esc help
  • DeltaForceMan
    Old No 7
    • Dec 2014
    • 101
    Just recently put power to this esc and hooked up my program box to it. The screen "update your esc or press ok" when I press ok the screen goes blank??? Would appreciate any input thanks.
    Good times had by all!
  • pescador
    • 503
    Do you have both leads from the esc plugged into the box like Diagram 2 opto esc in the instructions?
    Switch on?
    Brian
    Namba District 16
    1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
    • DeltaForceMan
      Old No 7
      • Dec 2014
      • 101
      Yes, the receiver lead and the lead that consists of a black and red wire. Bolth have been plugged in and it won't get past the first screen after o press ok it just goes blank... maybe its a program box problem??
      Thanks for your response
      • pescador
        • 503
        Did you try checking the box firmware thru the pc link? A long shot mine was up to date.
        Brian
        Namba District 16
        • DeltaForceMan
          Old No 7
          • Dec 2014
          • 101
          Maybe that's the problem.. I'll have to get the USB link and try it.
          • flraptor07
            • Aug 2013
            • 2451
            It's probably a firmware update problem, have you had this ESC a while and just now using it?
            • DeltaForceMan
              Old No 7
              • Dec 2014
              • 101
              Just got it a couple weeks ago.
              • flraptor07
                • Aug 2013
                • 2451
                Do you have these instructions? http://media.wix.com/ugd/6bc562_69a7...e1a9f4b490.pdf
                • DeltaForceMan
                  Old No 7
                  • Dec 2014
                  • 101
                  I did not but I haven't done anything out of the normal with this setup. I will go over all options.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    Go through those instructions and see if you missed something.
                    • jcald2000
                      • 786
                      The controller HAS to be connected to the computer to update software, other wise where is it going to get the update from?
