Swordfish computer link
  • Sonic24
    • Dec 2014
    • 38
    Hello all,
    I was able to load the Hifei V4.12 on my computer successfully from the provided disc. The treads on this web site were helpful there.
    However, I can’t get the software to recognize any of my ESCs. I have several Swordfish ESCs (300 and 220 Pro+). When I follow the “Connect ESC to PC” instructions provided, I get a red light on my USB linker. The instructions state I should get a green light.
    I have tried different Swordfish ESCs (with and without a BEC).
    I have tried different USB linkers.
    I don’t get a software option to manually select a com port.
    It appears my computer just isn’t seeing the ESC.
    As they are all doing the same thing, I assume the ESCs are fine. They can’t all be bad; it has got to be me missing something.
    What am I missing? Help please
  • photohoward1
    • 1781
    What drive is it on. It can be on any drive but the "C:"
    • Sonic24
      • Dec 2014
      • 38
      I only have the one hard drive (C)
      • photohoward1
        • 1781
        Load or instal it on a USB drive or an SD card.
        • Sonic24
          • Dec 2014
          • 38
          I just inserted a USB Drive.
          Reinstalled it on that drive using the "CP210xVCPInstaller_x64" file. I used the "Browse" option to select the USB drive for the target.
          Then used a brand new Swordfish 220 Pro+ that hasn't had any connectors soldered onto it (I thought perhaps I damaged the others when soldering bullets)
          it is performing the same. Red light on the "USB Linker" and the software just doesn't see the ESC.
          I know it is something I am doing wrong, I just can't figure it out.
          I do appreciate the help
          • Sonic24
            • Dec 2014
            • 38
            Hello all,
            Proof that "The Truth is out there"
            I kept searching this forum for the answer, and i found the solution to my problem. See thread http://forums.offshoreelectrics.com/...-Swordfish-esc
            My link works perfectly.
            Thanks to all
            • Michlee
              • 56
              Hi, when plug Hifei USB Linker to PC, the red LED of USB linker will on.
              Good to hear you can connect them all to PC now.
