Swordfish 240 esc 2 pack lipo setup
  • DeltaForceMan
    Old No 7
    • Dec 2014
    • 101
    If I'm running two lipo packs too a swordfish 240 esc will I be ok soldering a Y setup on the esc.. (like a stock traxxas erevo esc comes set up).
    Good times had by all!
    Why do you need a "Y"? if you are connecting the batteries in series, just hook up the batteries' + to- and the other + and - goes to the ESC.DSCN3213_3438.jpg
    if it is parallel then you need a parallel adapter . Kintec Parallel adapter.jpg
    I am assuming you are using bullet connecters.
      ***edit*** this only applies is your doing them in series. You never stated one way or the other.
      Here's how I did mine...
      This a seaking 180. I did the wires the same. Run the red one way, black the other and then a jumper between the positive left on one battery to the negative on the other battery. Essentially makes a loop through them. You can see it better on the swordfish 240. That black wire going under it is just a jumper. Hope this helps.
      • DeltaForceMan
        Old No 7
        • Dec 2014
        • 101
        Awesome, thanks guys!
        • 3-UP
          • Jul 2014
          • 97
          You still didn't mention in Series or Parallel ? Very important
            And what type of connectors?
            • DeltaForceMan
              Old No 7
              • Dec 2014
              • 101
              It would be two packs in series with 6.5 castle bullet connectors
                Thanks for letting us know.
